Home > Technical (L322) > Delayed Air Con
Page 7 of 8 <12345678>
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Out of interest, how much is a replacement AC compressor and control valve for an L322? My AC is all over the place too so I’ll probably budget to have that job done in the next few months. Happy to use Glenrands on recommendation as fairly local to me near Alton.
fanders
Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #598792 25th Jun 2021 8:57pm
mjdronfield
I think the control valve is part of the compressor, so if you have a new compressor you’ll be fine.
You can get it separate, but you might as well do compressor whilst it’s all stripped down. Don’t want that failing 2 weeks after you change the valve.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #598793 25th Jun 2021 9:05pm
mjdronfield
Sorry Fanders, I’m not sure your compressor is the same design, you’d better check. Is the strange valve thing only used on the 2010 onwards cars?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #598794 25th Jun 2021 9:07pm
fanders
I don’t know, but would expect the control valve and compressor to be separate components (I haven’t researched the system well enough). My AC compressor is fairly noisy, you can hear a marked change in noise level when engaging the system with the AC switch. So probably worn bearings, and worth changing the compressor and valve. I’m on 95,000 miles now.
fanders
2021 Hilux 2.4
Post #598802 25th Jun 2021 10:21pm
GraemeS
The valve is part of the compressor.
Post #598810 26th Jun 2021 12:01am
DrRob
For a 4.4 tdv8
https://www.advancedfactors.co.uk/lr056364...4026-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #598834 26th Jun 2021 8:20am
fanders
Just an update on my slow AC - went to Glenrands in Liphook today on Dr. Rob's recommendation and they diagnosed that the fill port Schrader valve was leaking and I was about 100g low on refrigerant. System drained down, leak tested and refilled and all seems good, much quieter than before. That was good, as I had prepared to cough up for replacement of some parts of the system.
Glenrands look like a good operation, friendly and knowledgable staff.
Hope this is of some help in these warm summer days (!! if only !!).
fanders
2021 Hilux 2.4
Post #600057 8th Jul 2021 2:53pm
Sonearly
Also had slow working AC, went for a recharge and mine was also 120gr low, now fully charged and pumps out cold air after a couple of minutes rather than the 10 mins before. Fingers crossed 🤞
Post #600060 8th Jul 2021 3:31pm
mjdronfield
That’s good then. Mine has never been right, so I’m not sure I will be that lucky....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #600062 8th Jul 2021 3:34pm
TomP
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Java Black
My AC problem (posted 18 June) is now fixed thanks to Dr Rob's Glenrands recommendation. It all boiled down to a defective 'Pollution Sensor'. After my experience with Glenrands, I'm happy to join Dr Rob in recommending the outfit. Specialists in Land Rover vehicles, and a pleasant bunch too, who will let you in the workshop, and share their expertise. Beats the main dealers with their fancy facades, inflated prices, and cappuccinos - Ross, the owner of Glenrands, made me a coffee in a mug which tasted very much like tea, but who's complaining - these are real Landrover people !!
Post #600109 9th Jul 2021 7:21am
DrRob
Quick update:
Air con functioning perfectly in this hot weather now I’ve had the compressor swapped out.
Glad to hear others are using Glenrands locally to Surrey/Sussex/Hampshire - great service and uses Advanced Factors for parts supply = a winning combo Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601035 18th Jul 2021 12:17pm
GGDR
Hi guys just resurrecting this thread because this job is on my "todo" list.
This morning I watched a new Samcrac video where he has this exact problem on a Bentayga
access is easy but it does make me wonder if the valve can be replaced in-situ?
I read through all the pages and I think I only saw compressor removal?
 Cheers, Greg
Post #688193 16th Mar 2024 8:58am
Sonearly
Sorry to disappoint but there is no way to change valve with the compressor in situ.
Post #688199 16th Mar 2024 10:31am
mjdronfield
I think on the L322 the end of the valve points to the engine block or something immovable, so you have to remove the air con compressor to get it out, and the consensus is that if you are doing that you might as well fit a new unit, complete with new valve.
What I never really got an answer to was whether there was an aftermarket compressor that didn’t have the valve issue, as a few folk had the same issue again after changing compressors… not straight after though…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #688206 16th Mar 2024 11:34am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #688207 16th Mar 2024 11:43am
