Home > General (L405) > Another crank failure
Kot
On the RRS forum yesterday another crank failure reported page 5 below, just 41k on the clock
https://www.rrsport.co.uk/forum/topic54590-60.html 2018 SE SDV8 4.4 Byron Blue
Post #594166 13th May 2021 6:09pm
mjdronfield
Ok, I’ve got an L322 4.4 TDV8..... and I get that generally folk only post on a forum when stuff is broken, but even a few crank failures reported on the 3.0 engine would be enough to make me avoid it. I don’t need that worry. I sometimes think a Disco 4 would be a nice practical car, I loved my D2, but the crank failures would make me avoid that also, and I don’t think there was any real engine alternative in the UK.....
If I get an L405, it will be a V8.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #594167 13th May 2021 6:29pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Had a D3 before the FF, brilliant motor, and always fancied a D4, but wouldn’t touch one with the preverbial pole.
Always amazes me how LR are allowed to get away major issues like the crank failure, and wasn’t there a problem with the Discovery Sport 2.0 engine?
Post #594170 13th May 2021 6:56pm
My D4 is a 2.7, it’s based on the same basic engine architecture as the 3.0. Can’t say I’ve had an issue with it, and they also have some issues with the crank failures. Tbh if I was going to see a failure I’m sure it would have gone by now!
The failures would put me Off owning a 3.0 unless I was protected in Some way, but if it came with a warranty which paid out of the crank failed then I could live with it. There is nothing that can't be fixed with a hammer😜😜
Post #594177 13th May 2021 8:06pm
knwatkins
I had a spun bearing on my 3.0. The crank was in one piece as I stopped the engine right away, but was obviously damaged.
Having been through this, it's sickening and the costs are ££££. Yes, I got it repaired which is documented here.
The chances of this happening are slim when you consider the thousands of T/SDV6s on the road, but when it happens, it ain't nice. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #594183 13th May 2021 9:03pm
Looks like the ingenium Diesel is taking over as most unreliable engine Shocked Rolling Eyes Went to my local MD and they had a line of 13 cars waiting for an engine! Shocked Shocked Shocked
Turbo bang and then picks up on the engine oil... Then BOOM!
Come on JLR...........
Post #594188 13th May 2021 11:53pm
Spike
United Kingdom 2004 Range Rover Vogue Td6 Monte Carlo Blue
Lots of info on this on the Disco3 forum, 2.7 and 3.0
Post #594202 14th May 2021 7:02am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I think the 2.7's snap the crank and the 3.0's spin the bearings. Was one of the reasons I went for an SD V8. It's most likely not going to happen had I chosen a SDV6, but did not want to take the chance.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #594205 14th May 2021 7:58am
GraemeS
My only concern with the 4.4 was if the primary turbo blew seals and fed the engine so I have devised that the EGR butterfly gets closed for 15 seconds whenever the ignition is switched off - no air, no combustion. But it appears from possible fault codes that the 3.6 TDV8 PCM caters for unexpected running and closes its butterflies and issues a fault code, which IMO should be done for all turbo diesel engines.
Post #594228 14th May 2021 11:02am
Slow progress
I know that feeling!
I really want an L322 but I’m nervous as everyone around tells me I’m an idiot whilst they sit in their BMW’s, Tesla’s and Lexii(!?), whilst none have them have ever owned one!
I’m going to go down the route suggested by a member on here which is to buy £2k or £3k below budget and set aside for any major issues. It’s a case of getting a feel for how much does it cost if;
- gearbox goes on td6 (£2.5k?)
-turbos blow on 3.6tdv8 (£4.5k?)
- timing chain and tensioner don’t 5.0s/c etc. (£2k??)
I also see Clarksons TDV8 has blown its turbos (3.6tdv8?) and he’s having it rebuilt!
Post #597918 18th Jun 2021 12:38pm
mjdronfield
Yes, Clarkson’s is a 3.6.....
All cars have their issues at some point. Might as well be sat in something nice whilst you wait for the recovery truck 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #597927 18th Jun 2021 2:12pm
ur20v
A Trap
As said above, every car and make has its ‘common’ issues and ‘uncommon’ issues… if you think buying a Lexus or other brand puts you in the ‘I can never break down or have any expense or inconvenient club’ you are wrong. It’s just the risk you take with electrical/mechanical devices.
There are some lemon models out there but even then you have to be unlucky… they can make a good car by mistake on Friday afternoon just before knock off 😂
Post #597928 18th Jun 2021 2:29pm
AnotherMutley
Ivan
The 3.0's snap cranks too.
Post #597929 18th Jun 2021 2:35pm
Slow progress
Rolling with laughter If only they let you stay in your vehicle when you get recovered! In my experience flat beds aren’t that comfortable inside 😀
Post #597935 18th Jun 2021 3:39pm
Slow progress
AnotherMutley wrote:
Ivan
I’m afraid the sdv6 is one engine I actually won’t go near! I know 2 people who’ve had the crank fail one with a Disco4 and one with a RRS
Post #597936 18th Jun 2021 3:48pm
