![]() | Home > General (L405) > Another crank failure |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
On the RRS forum yesterday another crank failure reported page 5 below, just 41k on the clock
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Ok, I’ve got an L322 4.4 TDV8..... and I get that generally folk only post on a forum when stuff is broken, but even a few crank failures reported on the 3.0 engine would be enough to make me avoid it. I don’t need that worry. I sometimes think a Disco 4 would be a nice practical car, I loved my D2, but the crank failures would make me avoid that also, and I don’t think there was any real engine alternative in the UK.....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
My D4 is a 2.7, it’s based on the same basic engine architecture as the 3.0. Can’t say I’ve had an issue with it, and they also have some issues with the crank failures. Tbh if I was going to see a failure I’m sure it would have gone by now!
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I had a spun bearing on my 3.0. The crank was in one piece as I stopped the engine right away, but was obviously damaged.
Looks like the ingenium Diesel is taking over as most unreliable engine |
Spike Member Since: 23 Sep 2019 Location: Northants Posts: 17 ![]() ![]() ![]() |
Lots of info on this on the Disco3 forum, 2.7 and 3.0 |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
I think the 2.7's snap the crank and the 3.0's spin the bearings. Was one of the reasons I went for an SD V8. It's most likely not going to happen had I chosen a SDV6, but did not want to take the chance.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
My only concern with the 4.4 was if the primary turbo blew seals and fed the engine so I have devised that the EGR butterfly gets closed for 15 seconds whenever the ignition is switched off - no air, no combustion. But it appears from possible fault codes that the 3.6 TDV8 PCM caters for unexpected running and closes its butterflies and issues a fault code, which IMO should be done for all turbo diesel engines. |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
I know that feeling!
Yes, Clarkson’s is a 3.6.....
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
As said above, every car and make has its ‘common’ issues and ‘uncommon’ issues… if you think buying a Lexus or other brand puts you in the ‘I can never break down or have any expense or inconvenient club’ you are wrong. It’s just the risk you take with electrical/mechanical devices.
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
The 3.0's snap cranks too. |
I’m afraid the sdv6 is one engine I actually won’t go near! I know 2 people who’ve had the crank fail one with a Disco4 and one with a RRS |
