Home > Technical (L322) > Starter motor replacement L322 TDV8
Page 4 of 9 <123456789>
mjdronfield
Ah, ok. Thanks.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #596290 3rd Jun 2021 1:00pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Mine is booked in at a Garage in Spain tomorrow.
Post #596884 8th Jun 2021 10:35pm
TeeMyob
Okay, so new starter fitted. Still got issues. New battery fitted. All okay now
Other than I am €900 down almost
Post #597110 10th Jun 2021 10:55pm
dhallworth
I replaced the starter on our 4.4 TDV8 almost 2 years ago now.
All I needed to remove was the undertray. The starter motor came out between the gaps in the tubular subframe. I didn’t need to remove a wheel, arch liner or anything else. You do need to be able to get under the car to do it that way though.
I reckon it took me 30 mins to get it out including removing the undertray and probably about the same to put it back on.
One of the easiest jobs I’ve ever done on the Full Fat.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #597111 10th Jun 2021 11:34pm
TeeMyob
Thank you.
If I had been at home in the UK, I would of tried it maybe. To be fair, I’ve plenty of other jobs to do here anyway. And the sun is shining . I will detail the costa later.
Post #597226 12th Jun 2021 7:28am
kooky_guy
Mine's just started playing up so I've been looking to get it replaced. Is there a reason why everyone is going for the Denso replacement rather than the oem product? Is it just price?
My local indy only wants to use a LR starter. Given mine has already had one starter replaced, I'm not particularly enthusiastic especially as it's priced at over £400. 2010 4.4 TDV8 Vogue SE
Post #598278 21st Jun 2021 2:45pm
Baltic Blue
Opie oils sell the Denso unit at a very good price, and just for today are offering 15% off.
Post #598279 21st Jun 2021 2:50pm
kooky_guy
Out of Stock unfortunately!
I have found one for £245 at Micksgarage.com. Anyone used them?
My Indy has agreed to fit one if I supply it now which I wasn't expecting! 2010 4.4 TDV8 Vogue SE
Post #598285 21st Jun 2021 3:51pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Shaun wrote:
The cable I replaced was the smaller one from the start relay in the fuse box to the solenoid, too much of a volt drop on it. Spliced a new one in the fuse box near the relay and found a convenient run down to the starter.
i have been trying to find the starter relay, could you tell me which fuse box it is in and which relay it is ,thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #617560 26th Dec 2021 8:20am
TeeMyob
Just to let you all know, the second replacement Starter has been fine.
Post #623019 8th Feb 2022 9:37pm
dhallworth
The original factory fit one was a Denso as far as I’m aware.
When ours failed the LR supplied one that I removed was a Denso and the one I fitted from Euro Car Parts was a Denso.
Euro Car Parts had the Denso one in stock at our local branch when I ordered ours so they obviously get through enough of them.
Post #623023 8th Feb 2022 10:33pm
johnboyairey
my experience with this issue has been..... bought car, at 196k, and discovered the intermittent starting issue.. tiny click, and no 'clunk' or whirr. removed starter, teasing it out to the side, past the roll bar, with wheel hanging down..with I think solenoid facing front of car, as not coming out other way... dismantled solenoid, and saw very black terminals... filed them, and reassembled. went first time... and may more times, all ok.... thought it was ok, as had no more no-starts.... until about a week ago, (199k) got an odd no-start... but couldn't be sure it was me not timing my finger press correctly.... and then next day, the worst ever one. -took an hour and half to eventually go again, fortunately at a petrol pump, at 1am, so no holding up etc... got under, and tapped it a good few times, just incase, with wheel brace, then large hammer, leant to me... wasn't having it.... so a short snooze, and then tried it. (1.5hrs!) it eventually went, and as id guessed this might happen, and wanted to prove the fact, seemed like it occurs when car is quite warm, and you return to car within 10 mins of leaving it... So, I bought a secondhand starter, just so I could prove the issue, then I would/will invest the £400 for a new one. -only £35 so worth a gamble.. its been on a few days, and issue has gone away. (for now!).
watch this space.
Post #623024 8th Feb 2022 11:02pm
GraemeS
I have pre-emptively installed a motor bike starter relay at the starter solenoid to power the starter solenoid from the main battery cable, using the solenoid trigger wire to trigger the motor bike relay. The solenoid now very positively closes its contacts and the starter jumps to life starting the engine immediately. Mitsubishi Electrics fits the extra relay to its after market truck starter motors to ensure that the solenoids get full voltage so that the life of the solenoids isn't compromised by poor vehicle wiring. Our vehicles have poor wiring for the solenoid, being very undersized for the current draw for the wire length.
Post #623026 9th Feb 2022 1:23am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
totally agree Bow down
Whilst my starting has greatly improved and many gremlin solved with wiring work and new relays I feel the solonoid contact can be further improved specially with battery voltage on the low side (still havent fixed the parasytic drain)
What is a good brand setup you would recommend? also where did you pick up the signal?
Thanks In advance SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #623095 9th Feb 2022 8:05pm
ffrr14
watch this space.
I have experienced the same issue and had put it down to low SOC (drain) and a heat soaked starter solenoid not making adequate contact. I feel the next logical step would be to add Grame's Mod and go from there SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #623098 9th Feb 2022 8:19pm
