Home > Technical (L322) > Starter motor replacement L322 TDV8
Page 9 of 9 <123456789
Buckie1967
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Buckingham Blue
I am in the process of changing the starter motor.
I have managed to get the old one detached but I have tried for an hour to drop it down via the little triangular opening in the sub frame. I have watched the Ed China you tube video where he manages to do it and I think he is working on a 4.4tdv8 like mine.......I have had it in every configuration possible and it won't drop.
It appears there is simply not enough clearance above for me to get this thing straightened up so that it will drop out vertically. There are no obvious spaces or voids above the loose starter motor to push it into so that I can straighten it sufficiently to allow it to drop out of this gap in the subframe (Seems to be two separate heat shields which keep impinging any progress)..
I will remove the wheel tomorrow and the heat shields and attempt to get it out that way (sideways).
Post #698266 17th Aug 2024 8:54pm
RovingCanary
Was your suspension raised prior to starting ? I had my wheel and heat shield off for easy access, but it came out via the triangle opening you mentioned. If it helps, it took me over an hour, and it felt like it was impossible, until suddenly it wasn't. Pretty sure it came out with the pinion facing downwards, and it needed a twist while rotating, but it's not a job I ever want to do again!
Post #698268 17th Aug 2024 9:13pm
GGDR
I have managed to get the old one detached but I have tried for an hour to drop it down via the little triangular opening in the sub frame. ...).
it will definitely come thought the triangle.
IIRC you go backwards, tilt the rear of the SM upwards, and eventually you can tip the shaft end down through the triangle. Takes a while.
Maybe you didn't swear enough? You def need to swear sufficiently to get it out.
. Cheers, Greg
Post #698272 17th Aug 2024 10:26pm
Buckie1967
Thanks guys.......
The swearing started when I first got under the vehicle and noted one of my newly repaired brake pipes weeping slightly which I paid a mechanic to replace a week ago as the originals were corroded. Evil or Very Mad
I put the cars suspension up high to off road and then drove the front wheels up onto two breeze blocks to help a little more with access. So I am doing this job on my drive but to be fair I have plenty of room under the vehicle.
I did note in the video that the end of the SM that was unbolted (which contains the gearing) came out last when it dropped down out of the triangle part of the sub frame.
Thinking about the suspension height....would this really make a difference attacking the problem from underneath. Wouldn't the subframe leave the same gap above it no matter what the ride height is? I thought this may only make a difference if attempting access from the side via the wheel arch where the antisway bar becomes an issue.
I am going to fit a parallel trigger wire (50amp 6mm2) too, and treat the front subframe to some wire brushing, Neutrarust primer finished off with some Lanoguard.
and then source one of the undertrays which is missing!!!
Post #698274 18th Aug 2024 1:18am
Buckie1967
Update.....I removed the front drivers wheel and the side heat shield (the flexible tin one which is secured with 4 screws, not the metal one above the SM) and this gave a little more head room to manoeuvre the SM so that I could drop it down out of the subframe.
New SM fitted, fresh trigger wire spliced into the existing wire and it started first time on the button so hopefully that is the end of that issue for the foreseeable.
It started to play up when I was away at the Lake District so just glad I was able to get home. I already had a new SM in my garage as it is like a Land Rover parts warehouse.
Many thanks to the contributors on this board it is fantastic and one of the reasons I purchased an L322 due to the wealth of knowledge at your finger tips.
Post #698323 18th Aug 2024 5:56pm
RovingCanary
Great work, rewarding job to complete. Mine was okay with intermittent starting for a couple of months, but was getting worse very quickly so not one to sleep on!
Post #698344 18th Aug 2024 8:46pm
Gas
Changed the starter on my 3.6 V8 yesterday using this as a guide.
Took about 2-3 hours including break to remove Range Rover from my eye.(this happens a lot here)
I used a new Denso unit which was exactly the same as what came off.
Everything worked as advertised no drama really,starter came out the side with the wheel still attached.
Everything is tight but it will come out, I jacked up the car to make the front suspension drop which definitely made the front ARB give me more room.
I put the suspension into off road and drove up onto a couple of blocks to gain extra height.
I cut an old 17mm spanner in half to get at the positive lead nut, this made things a lot easier as my selection of sockets and ratchets didn’t fit too well.
Will carry out the trigger wire mod next time the sun shines.
Investigated the solenoid on the old starter to find it full of water so I’m surprised it worked at all!
Post #698416 19th Aug 2024 7:36pm
GraemeS
Australia
Today I replaced my previous preventative bike starter relay at the starter solenoid with 4mm2 wire direct from the fuse box. On 2 occasions the bike relay had to be removed, firstly to remove the starter motor to fit a crankshaft locking tool then recently to lean the steering rack over to replace the input shaft seal after which I didn't refit the bike relay. The parallel wire is a simpler solution, not adding more electrical complexity and no bulk at the starter solenoid.
Post #700134 15th Sep 2024 5:09am
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Just had the starter motor changed and asked if we might have a look at the solonoid trigger voltage during starting and the garage owner, who is a friend, sggested popping back in the evening so we could muck about. With a digital probe the initial was 9.0V. Now the transient nature of this may be a little adrift as I doubt the probe is super fast (Autel PS100) but nevertheless I decided to have a go at fitting a secondary trigger relay down by the strater that I had previously constructed. It fits without any splicing and is fully removable. Repeated the probe test at the solonoid feed and now 11.0V. Battery was 12.3V so less than ideal but then again a 2.0V improvement is not nothing. Also noted after a few start cycles that the car would start so fast it was no longer able to 'catch' the transient voltage before the ECM called a halt.
As an aside, the local starter and alternator specialist had the old one apart and found the contacts beyond repair and spares are not available. He suggested fitting a decent alternative which is fully reparable and a bit cheaper than the Denso 1207. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #703388 29th Oct 2024 7:37pm
lofty248
Australia
Had the click and no start, removed the starter and cleaned up the contacts and forgot to put the two Philips screws back in to the brush section (there were too many cooks in the kitchen at the time, but end of the day it was my fault), the car started up fantastically with clean contacts, once!
After the complete destruction of that starter I put a brand new Denso unit in a few days later, and ran a replacement trigger wire through a 75a relay with a self resetting fuse (50A).
Car was happy again for a bit... Few months later and its back to its old shenanigan's, seems to be more likely to do it after driving a while then it has a harder time starting back up again.
Alternator is reading 13.8 idle and 14.0 at cruising, battery seems to read between 12.3-12.7 depending on how long its been sitting. Need to get a reading when it clicks, but I'm usually too stressed about getting stranded to remember.
Any help would be greatly appreciated. 2010 Vogue 4.4 TDI
2005 Subaru Outback H6 3.0
1991 Nissan Pulsar GTI-R AWD 2.0
Post #704686 18th Nov 2024 7:18am
RovingCanary
Only thing I could think to try is the battery voltages with just the ignition on but engine off (so conditions before starter would kick in). I found mine dropped a fair amount, of course moreso in the dark if your lights are on auto. As yours is clicking again it sounds likely you will need to pull the starter out again in anycase 😞 must be an underlying cause unless he new unit is faulty...
Post #704718 18th Nov 2024 4:03pm
