Home > Technical (L322) > Starter motor replacement L322 TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
Ah, ok. Thanks.
3rd Jun 2021 1:00pm |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 |
Mine is booked in at a Garage in Spain tomorrow. |
8th Jun 2021 10:35pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3141 |
I replaced the starter on our 4.4 TDV8 almost 2 years ago now.
10th Jun 2021 11:34pm |
Thank you.
12th Jun 2021 7:28am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Mine's just started playing up so I've been looking to get it replaced. Is there a reason why everyone is going for the Denso replacement rather than the oem product? Is it just price?
21st Jun 2021 2:45pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
Opie oils sell the Denso unit at a very good price, and just for today are offering 15% off.
21st Jun 2021 2:50pm |
Out of Stock unfortunately!
21st Jun 2021 3:51pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 760 |
i have been trying to find the starter relay, could you tell me which fuse box it is in and which relay it is ,thanks RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
26th Dec 2021 8:20am |
Just to let you all know, the second replacement Starter has been fine. |
8th Feb 2022 9:37pm |
The original factory fit one was a Denso as far as I’m aware.
8th Feb 2022 10:33pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
my experience with this issue has been..... bought car, at 196k, and discovered the intermittent starting issue.. tiny click, and no 'clunk' or whirr. removed starter, teasing it out to the side, past the roll bar, with wheel hanging down..with I think solenoid facing front of car, as not coming out other way... dismantled solenoid, and saw very black terminals... filed them, and reassembled. went first time... and may more times, all ok.... thought it was ok, as had no more no-starts.... until about a week ago, (199k) got an odd no-start... but couldn't be sure it was me not timing my finger press correctly.... and then next day, the worst ever one. -took an hour and half to eventually go again, fortunately at a petrol pump, at 1am, so no holding up etc... got under, and tapped it a good few times, just incase, with wheel brace, then large hammer, leant to me... wasn't having it.... so a short snooze, and then tried it. (1.5hrs!) it eventually went, and as id guessed this might happen, and wanted to prove the fact, seemed like it occurs when car is quite warm, and you return to car within 10 mins of leaving it... So, I bought a secondhand starter, just so I could prove the issue, then I would/will invest the £400 for a new one. -only £35 so worth a gamble.. its been on a few days, and issue has gone away. (for now!).
8th Feb 2022 11:02pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2552 |
I have pre-emptively installed a motor bike starter relay at the starter solenoid to power the starter solenoid from the main battery cable, using the solenoid trigger wire to trigger the motor bike relay. The solenoid now very positively closes its contacts and the starter jumps to life starting the engine immediately. Mitsubishi Electrics fits the extra relay to its after market truck starter motors to ensure that the solenoids get full voltage so that the life of the solenoids isn't compromised by poor vehicle wiring. Our vehicles have poor wiring for the solenoid, being very undersized for the current draw for the wire length. |
9th Feb 2022 1:23am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
totally agree
9th Feb 2022 8:05pm |
I have experienced the same issue and had put it down to low SOC (drain) and a heat soaked starter solenoid not making adequate contact. I feel the next logical step would be to add Grame's Mod and go from there SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
9th Feb 2022 8:19pm |
