Home > Technical (L322) > fan cowling up date
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
fan cowling up date
would you say that by putting half of the cowl back top half would make much difference to the rad cooling . i think i can fix the top part back and this would make it so easy to remove to get front of engine next time just your thoughts or input this is on the 4.2 sc
up date on the fan cowl i have put it all back but in 4 sections . the right side bottom is fixed any way so i fixed the left side bottom after cutting it half way up the side and put 2 stripes of alloy for the top half to slot in to so now bottom is fixed . now for the top i did try and keep it as one piece but no good so cut it half again at the very top made a temp plate to see if it would work put 4 spire clips and fitted the plate on top the fixings in the rad i put 2 5mm bolts with lock nuts so it holds the bolt in place and then the top will just slide over the bolt so you can put washer and flange nut on and nice and solid makes going in to the front of the engine very easy next time round new bolts came to day for the plate so all fixed
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #596872 8th Jun 2021 8:58pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Cowlings do make a big difference to the amount of air a fan moves. That said, if theres plenty of air movement a loss of efficiency may not matter. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #596892 9th Jun 2021 5:49am
It was designed to cool the engine while towing a trailer across a desert... The fan needs the cowl to direct the air it pulls from the front of the rad to the back, if it's not there in its entirety the fan can't draw air through the rad, it pulls air in from the sides and does very little to cool...
It will be fine for most of your UK use but get stuck in traffic on a hot day and you will wish you had put it back to how it was designed..... Thumbs Up Pete
Post #596909 9th Jun 2021 9:58am
oggy
fan cowl update i did put all fan cowl back but in 4 pieces new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #598621 24th Jun 2021 8:30pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Good to hear that you have put all of it back. Totally agree with Haylands comments & can vouch for that issue.
I did run for a short period without a fan cowl & although it worked ok, it did get pretty hot a couple of times in stop start traffic.
Since replacing the cowl I've never had an issue, despite some very hot days & long jams.
Post #598632 24th Jun 2021 9:54pm
