Home > Technical (L322) > 3.6 TDV8 Turbo Whistle?
RosieL322
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Hi All,
Another question about Rosie. She has a very noticeable whistle from the turbo when accelerating. I’ve had quite a few different turbo diesels before and never really heard the turbo whistle. Is this common or a sign of an upcoming problem? Thanks in advance, Mark
Post #597328 13th Jun 2021 2:18pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
I too get a kind of whistle on my TDV8 4.4 that is only noticeable in summer months when the windows are open, just after acceleration and you let off the gas pedal... Sound a bit like air brakes... big truck like... I kinda like it though... Shocked
Post #597345 13th Jun 2021 5:00pm
jackie-o
Netherlands
sounds like a boost leak? RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #597355 13th Jun 2021 6:21pm
RosieL322
I was thinking that but no engine lights or faults displayed. Any way of checking if I have a leak?
Post #597360 13th Jun 2021 7:09pm
jackie-o
Netherlands
Someone a lot more knowledgeable than I will probably say something more clever but I would get it in for a high pressure smoke test?
The 3.6 is known for intercooler hoses so maybe have that checked first? If any of them are cracked it should make a whistle?
Easy fix if so Thumbs Up RR Vogue 4.4 TDV8 - 11
Post #597362 13th Jun 2021 7:19pm
RJDS
Other cars are known for having waste gate sealing issues, usually identified by reduced boost pressure. Is it possible to check the boost pressure against the ‘norm’ to eliminate this as an issue. The fix is adjustment of the waste gate actuator arm. 2010 TDV8 3.6 Galway Green
Post #598592 24th Jun 2021 1:31pm
RosieL322
I’ve had Rosie in to my local specialist for a code read. No loss of boost on the codes but a turbo actuator fault. They have lubed the actuator and reset the error but whistle still present. It’s not causing any issues so far, but would like to prevent anything serious if possible. She is back in for a full service and transmission flush in a couple of weeks so will see if they notice anything else. That’s you all for the suggestions. Mark
Post #598620 24th Jun 2021 7:29pm
