Home > General (L405) > Cetane Booster ?
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Cetane Booster ?
For fear of treading on a land mine here but...
Long term, is it really worht it ??
Post #594670 19th May 2021 7:34am
AnotherMutley
Never heard of this before, had to google it.
Its one of those things that will be divisive, I suppose it depends on whether your car is covered by some form of warranty, if you were to use it and had an issue, they could use it as an excuse to get out of their obligations.
Post #594677 19th May 2021 8:51am
Ragingrover
Thus my opening sentance.
I've used this stuff before in various cars but want others opinions before sharing my own
Post #594680 19th May 2021 9:07am
Broadoakboy
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
On the back of the various conversations on this forum I decided to bite the bullet and so I have been adding cetane into my fuel for nearly a year now.
I believe there is a difference in the engine's performance/responsiveness but because of that, I may not have improved the MPG, although getting to a cruising speed at a quicker rate probably helps overall.
The car doesn't appear to be running hotter, there are no weird smells, exhaust is clean/nil smoke etc and in my mind the engine is quieter.
I have experimented with % of extra Cetane per litres of fuel and have settled at 1ml per litre. A 100 ml syringe and some clear O2 tubing from Amazon helps!
I bought 25 litres for £25. I checked a moment ago and the same product is now £35.
Post #594690 19th May 2021 10:40am
AnotherMutley
Have you done a comparison against something like Shell V-Power, I'm guessing the Cetane will work out cheaper because its an additive and one container will do a lot of tank fulls?
Post #594692 19th May 2021 10:46am
Ragingrover
There is a quite a price variation dependant on brand / supplier. Its not cheap stuff
As a matter of curiosity what vehicle do you run it in and what brand of addative ?
I've had varied success dependant on vehicle RR/Merc/BMW but never fealt a difference between plain labelled vs branded stuff.
Post #594700 19th May 2021 11:46am
Merchy
As they all use the same narrow range of chemicals, I can't see much of a difference between different brands.
Some may claim to add extra ingredients to clean pumps and injectors etc.
My only concern with these additives is if you regularly add 'too much', you can decrease the lubricity of the fuel thus increasing the wear rate on fuel pumps. Diesel fuel is obviously made to set standards, a minimum lubricity rating is one of these standards.
Post #594708 19th May 2021 1:02pm
Broadoakboy
I purchased HYDRA EHN-99, 2-Ethylhexyl-Nitrate 99% Pure 2 EHN Performance Enhancer Cetane Booster Diesel Treatment.
I am conscious of not using too much for the reasons stated previously, I am mindful of never going over my self determined
1:1 ratio and every now & then I run a tank without adding the cetane.
I have a SDV8 with 60k on the clock.
Given the price of super diesel my basic man-math has told me I am saving!
As a side note, back in Oct I took the lid off of the container to add some to my fuel and couldn't smell it........that is what alerted me to the fact I had caught COVID!! LOL
Post #594711 19th May 2021 1:58pm
ur20v
A Trap
So all information is anecdotal at best... but Cetane is a good Covid test, conclusion even snake oil has a purpose 😂
Post #594714 19th May 2021 2:14pm
Broadoakboy
Rolling with laughter
Great comment and you are correct, I am responding to questions on a forum with personal experience and anecdotes, nothing more.
My car, my choice right!
Post #594721 19th May 2021 4:39pm
ur20v
A Trap
Not going to argue... your money and will... plus it could literally have saved your life or loved one... got to be worth the price on the tin to you... for others, mileage may vary 👍
Post #594722 19th May 2021 4:47pm
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
This article might help;
https://www.bellperformance.com/bell-perfo...ting-myths
Think I will just stick to the premium stuff lol. "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #594738 19th May 2021 6:15pm
FlyingTrotter
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I did a major dispute related to Cetane - a dispute between the main producers of the various additives - as I’m sure you know modern diesel contains a host of additives including cetane and its competitor additives - i am not aware of any of the main fuel manufacturers disclosing their formula and so how a consumer can meaningfully gauge the right amount of any additive to add in order to create a superior end product is beyond me but if it works for you then fine.
Post #595035 22nd May 2021 8:37pm
