![]() | Home > General (L405) > Cetane Booster ? |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
For fear of treading on a land mine here but...
Thus my opening sentance.
Broadoakboy Member Since: 23 Nov 2020 Location: Wiltshire Posts: 26 ![]() ![]() ![]() |
On the back of the various conversations on this forum I decided to bite the bullet and so I have been adding cetane into my fuel for nearly a year now.
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
Have you done a comparison against something like Shell V-Power, I'm guessing the Cetane will work out cheaper because its an additive and one container will do a lot of tank fulls? |
There is a quite a price variation dependant on brand / supplier. Its not cheap stuff
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
As they all use the same narrow range of chemicals, I can't see much of a difference between different brands.
I purchased HYDRA EHN-99, 2-Ethylhexyl-Nitrate 99% Pure 2 EHN Performance Enhancer Cetane Booster Diesel Treatment.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
So all information is anecdotal at best... but Cetane is a good Covid test, conclusion even snake oil has a purpose š |
Not going to argue... your money and will... plus it could literally have saved your life or loved one... got to be worth the price on the tin to you... for others, mileage may vary š |
Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 413 ![]() ![]() ![]() |
This article might help;
FlyingTrotter Member Since: 10 Nov 2013 Location: London Posts: 79 ![]() ![]() ![]() |
I did a major dispute related to Cetane - a dispute between the main producers of the various additives - as Iām sure you know modern diesel contains a host of additives including cetane and its competitor additives - i am not aware of any of the main fuel manufacturers disclosing their formula and so how a consumer can meaningfully gauge the right amount of any additive to add in order to create a superior end product is beyond me but if it works for you then fine. |
