Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Brave man, good luck, watching with interest. BMW i3 Electric Car
4th Mar 2021 3:19am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Nah, I've no garage and not only do you need a garage, you really need a ramp. If I had those, I'd be there 100% I initially concluded, looking at that sump pic and the gallery circled, that you would be drilling into the gallery alone. But reading the instructions a few more times gave me a feeling you do have to drill though the two walls and into the main sump chamber. Whilst Graeme's right about swarf pulling backwards, it's aluminium swarf and if any gets into the sump the magnet (assuming there is a magnet) won't pick it. £80's a nice sweetener though! AJG had studied your pics many a time but I hadn't seen the subframe dropped. Impressive in itself. Thing is if the subframe's dropped, I wonder why you wouldn't whip the sump off, sort the drain, flush it all and refit....? Dunno. Probably a good reason but worth thinking though... . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
4th Mar 2021 10:11pm |
I suppose I probably would drop the sump as you say. Just thinking it through though, how likely is dwarf going to get in the sump? Highly unlikely if care is taken, if it did how much would get through the strainer and if that did happen a tiny fragment of soft aluminium how much damage would happen. I think the chances are zero.
5th Mar 2021 9:10am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 877 |
Dwarf in the sump is definitely not good! |
5th Mar 2021 9:52am |
I mean if he could sort out better draining I'm fine with it..
5th Mar 2021 10:09am |
Edward Member Since: 17 Sep 2016 Location: Wiltshire Posts: 12 |
Hi, what sort of oil consumption are people experiencing with this problem? |
5th Mar 2021 7:10pm |
steve57060 Member Since: 03 Oct 2018 Location: Derby - Nottm Posts: 14 |
Oil consumption is not noticeable as amount in sump is vast
5th Mar 2021 10:35pm |
LOL, big fingers, small keys on the phone, no dwarfs were harmed in the mod. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
6th Mar 2021 5:45am |
Fair enough, I am thinking the same about mine (keeping it). I have the engine out of mine currently to fix general oil leaks and to find the source of quite a significant usage of oil - about 1.5 L in 200 miles... Lucky it does have such a vast sump! |
6th Mar 2021 7:11am |
Edward set up a post, not that many engines come out, well not many here... we'd love to learn about your findings. Assume you have a 4.4TDV8 ?
Twin turbo diesel V8 - a titan that is unlikely to return . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
6th Mar 2021 7:45am |
Taken time to reply as needed to test result. Good news seems to be no more smoke above 3000 rpm.
29th Apr 2021 10:17pm |
I'm with you on the disbelief, how can it really make that much difference...... but it does!
30th Apr 2021 4:39am |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 |
You wouldnt happen to have the details of where you bought the kit from, if they are still available i will pick one up also. Cheers. Also own a 1976 Land Rover 101 3.5 V8. Previously owned 1991 Range Rover Vogue 3.9 V8. |
6th Sep 2022 8:21pm |
Hi The item was on ebay in Germany at a garage clearance. There was a problem with Brexit paperwork but eventually arrived. The sellers were reluctant to send as all the paperwork had to be done by them. I think it was for the L405 but with a bit of bending it fitted OK. Can recommend as no smoke whatsoever now (minor miracle) for just 1 pipe. Well worth the effort. Think Maltings do mod kit but you will have to check
7th Sep 2022 9:18am |
