![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Amazing well done. Got a link?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
I note that there's a later part number LR083155 for the pump that suits all 4.4s but that the original part number LR022758 isn't superseding to the later number when the original number is searched for. Microcat 2012 shows the MY13 L405 as having the original part number. |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
It looks like I had the last one it was the later part number LR083155 that I purchased. The company was Parks Motor Group.
Previously owned 1991 Range Rover Vogue 3.9 V8. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Great feedback and definitely worth trying a new pump as a first fix attempt for smoke screen cars |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
Shaun - did this cure yours? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
InlovewithRR Member Since: 20 May 2023 Location: London Posts: 13 ![]() ![]() ![]() |
Hi Guys,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
Whip your oil filter out and see if the valve is on it's post correctly and not loose in the bottom.
I'm checking mine at next oil change. May also account for the oil light on cold start when parked on a slope. 2012 TDV8 Vogue (L322) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
I didn’t know it served a valve function, I’ve always just thought it was a tensioner spring for the oil filter element, so will also be paying more attention to it every oil change.
How many people actually look down there let alone knew this existed as you have to climb on the engine or use a mirror. 2012 TDV8 Vogue (L322) |
I always clean it out, but have never removed the “spring”
V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
I do ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
I do as well, because it's surprising how much more dirty oil you can get out with a syringe and a tube. That's how I spotted my 'spring valve' was loose. |
