![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Is there any update L322 TDV8 2011 Autobiography
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
1500km, all fine. |
Yellopin Member Since: 03 Feb 2023 Location: Telford Posts: 31 ![]() ![]() ![]() |
So….do we just strip pump down and try and work it out? Is it obvious then? Got a few days off this week and a brand new pump to put on. Might have a play with the one I remove to see if I can work out what the issue with them is then. Wish me luck. 2011 4.4 TDV8 Autobiography Ipanema sand
Hi Yellopin
I’ll have a look Shaun. I can’t promise anything but I’ll have a play. I was going to write more but deleted it and will just see what I find, if anything and share my findings. 2011 4.4 TDV8 Autobiography Ipanema sand
glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21 ![]() ![]() |
Sorry for the novice question but what is the Turbo oil drain mod? I have no idea |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
It’s detailed on the forum in quite a few posts. Essentially some cars smoked under acceleration as the oil built up as it didn’t drain from the turbos properly when driven at low rpm for days on end. An extra drain pipe was added as the fix by LR that needed a hole drilling in the engine block for the oil to get back to the sump. It was fitted by the factory during the L405 production but never on the L322. Other garages can do it, seems it’s about £1000. Some cars never need it though.
Thanks for the explanation. Mine doesn't smoke to I assume its fine. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If you drive around for 20 or 30 miles keeping below 2500 rpm, in 'waft' mode. Then you give it a bootful and go above 2500 rpm, thats when the smoke appeared, in my case it was like something from James Bond, an absolute smoke screen. I had the turbo drain mod done by Green Oval Garage, and the problem was cured. It seems now however there are other theories relating to scavenge pump which may also resolve the problem by different means and much cheaper. BMW i3 Electric Car
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
It's an interesting subject and it seems some engines have this problem and some don't.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
These girls run ‘sequential’ turbos & the second doesn’t kick in until you reach 2700-2800rpm. So under normal driving the poor old second turbo sits there doing sod all, ingesting the odd drip of oil through the seals. What I & others tend to do every now & again, when up to running temp, run her up through the gears above 2800rpm, this then kicks the second turbo in & clears ‘anything’ sitting in the second turbo. I get a puff every now & again when I do this, but it helps spool up the turbo. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice! Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
I do some higher revs most of the time I drive, no smoke ever. Very clean exhaust gases always. |
Ok guys, Iam ready to do for one of you scavange pump mod. For free, only shipping cost.
barted Member Since: 28 Apr 2013 Location: Warsaw Posts: 3 ![]() ![]() ![]() |
I am happy to send you my vacuum pump. I am actually planning to replace it with a new one, hoping it will address the problem. I am actually not getting any smoke issues, but there is some oil in the intercooler and exhaust pipe from the second LH turbo charger.
