![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Happy days then |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
I've ran the bell remap and patch for a couple of years with the valves removed (throttle butterfly valve) without any issues.... In that regard car runs perfectly. Bas say they must be removed but is vauge as to why from memory... I guess he wants to know they won't try to close causing further problems... Either way I like the idea that they are gone as they can only be restrictive Dave 2010 3.6TDV8 Autobiography Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20 GAP Diagnostics Past - 02 & 03 TD6 And an 1984 Classic |
Tg87 Member Since: 09 May 2019 Location: Suffolk Posts: 21 ![]() ![]() |
Great thanks.
Glewpot Member Since: 21 Nov 2018 Location: Derbyshire Posts: 13 ![]() ![]() ![]() |
Done the delete today to pass some time, not contemplated the map out as a few members seem to running fine without. Welcome some thoughts on mapping the EGR butterflies v leaving connected with to the ECU ! |
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Just done this today on mine using the eBay kit. Sounds quieter, no engine light came on, and easy to do but very fiddly. Took about an hour or just over.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I’m seriously thinking about removing the remap and putting it back to standard but I’m worried about the EML coming on if I do. Currently it’s remapped with a digital and mechanical EGR delete. If I re-install the standard map then the EGRs will start to work again and I’m told the ecu is different on the 2010 models. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
i have had my 2010 mapped and egr mapped and delete and it’s made a massive difference on performance and mpg |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
so anybody with TDV8 2010 with DPFs sucessfully running with EGRs delete for some time?
My 2010 hasn’t got a dpf and I have only ever seen two with as I believe it was an option in the uk from what I get told you need the egr’s if you have a dpf |
Issues"?? You have a remap which includes an egr delete file? What fault codes were you getting if you know? I dot see how the dpf's relate to the egr system in any way.. other than they should be removed and mapped out also ![]() ![]() Dave 2010 3.6TDV8 Autobiography Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20 GAP Diagnostics Past - 02 & 03 TD6 And an 1984 Classic |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
My understanding is that functioning EGRs are required for DPF regen to take place.
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
M 2007MY 3.6TDV8 been running with the EGRs blanked off , but NOT deleted from the ECU software for the last 18 months without any problems or EML illumination.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 675 ![]() ![]() ![]() |
Hey guys I'm looking to do this on my Overfinch but searching eBay i can only find the blanking kits for the tdv6 not the tdv8. Are they same ones you can use on the tdv8 or different? And they don't come with the shorter bolts. Be great if some of you good people on here could put me in the right direction? Thanks. |
