Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles
Page 9 of 12 <123 ... 89 101112>
uzp315
Happy days then Smile Until the next trauma. Thanks for the reply Smile
Post #542686 1st Feb 2020 6:58pm
Tg87
Sorry to add some extra questions, did everyone that deleted remove the butterfly valves? I was looking at getting the ECU patch from bell auto services, they say both must be done? I just wondered if removing the valves affected anything else, cold start etc. Or is it better to get a tuner add the patch? If so any advise on one in Suffolk either mobile or a workshop?
Post #549978 11th Apr 2020 11:44am
ur20v
A Trap
Deleted
Post #549979 11th Apr 2020 12:03pm
Bluegreygreen Rangie 2
Australia
I've ran the bell remap and patch for a couple of years with the valves removed (throttle butterfly valve) without any issues.... In that regard car runs perfectly. Bas say they must be removed but is vauge as to why from memory... I guess he wants to know they won't try to close causing further problems... Either way I like the idea that they are gone as they can only be restrictive
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #550203 13th Apr 2020 12:44pm
Tg87
Great thanks.
I just spoke with BAS, they said on the 3.6 it can be a bit of a faff to take them out and they haven’t had any reported problems with not taking them out so not to worry. Blanking plates installed (one of the easier jobs I’ve done), so for no EML but 2-3 better mpg! Not what I did it for but very nice!
Post #550311 14th Apr 2020 2:14pm
Glewpot
United Kingdom 2008 Range Rover Vogue SE TDV8 Santorini Black
Done the delete today to pass some time, not contemplated the map out as a few members seem to running fine without. Welcome some thoughts on mapping the EGR butterflies v leaving connected with to the ECU !
Post #550416 15th Apr 2020 5:41pm
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Just done this today on mine using the eBay kit. Sounds quieter, no engine light came on, and easy to do but very fiddly. Took about an hour or just over.
The kit was basically £35. I also bought a blanking plate for the wife's Freelancer 2, for less than £4. 5 mins to fit and it is also quieter and the MPG has improved.
Post #561145 12th Jul 2020 2:19pm
Andy
I’m seriously thinking about removing the remap and putting it back to standard but I’m worried about the EML coming on if I do. Currently it’s remapped with a digital and mechanical EGR delete. If I re-install the standard map then the EGRs will start to work again and I’m told the ecu is different on the 2010 models. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #564125 10th Aug 2020 4:18pm
darrenm
i have had my 2010 mapped and egr mapped and delete and it’s made a massive difference on performance and mpg
Post #564149 10th Aug 2020 6:37pm
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
so anybody with TDV8 2010 with DPFs sucessfully running with EGRs delete for some time?
Mine 2010 having issues with EGRs delete + remap so today i put original software back to ECU and heading to replace defective EGRs but ... is it possible to leave them blanked off but working normally?
I dont want them but i dont want to remap them off and solving any issues again
Post #565408 24th Aug 2020 11:53pm
darrenm
My 2010 hasn’t got a dpf and I have only ever seen two with as I believe it was an option in the uk from what I get told you need the egr’s if you have a dpf
Post #565416 25th Aug 2020 7:45am
Australia
Issues"??
You have a remap which includes an egr delete file?
What fault codes were you getting if you know?
I dot see how the dpf's relate to the egr system in any way.. other than they should be removed and mapped out also Razz Thumbs Up
GAP Diagnostics
Post #565579 26th Aug 2020 3:34pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
My understanding is that functioning EGRs are required for DPF regen to take place.
https://www.darksidedevelopments.co.uk/egr-removal-delete/ 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #565606 26th Aug 2020 8:25pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
M 2007MY 3.6TDV8 been running with the EGRs blanked off , but NOT deleted from the ECU software for the last 18 months without any problems or EML illumination.
Unfortunately, the EML has now decided to come on & checking with the GAP has confirmed a mismatch of EGR behaviour vs demand.
I haven't investigated further yet, but presumably my EGRs have continued to deteriorate to the point they're occasionally sticking, causing the error & EML coming on.
I'm not sure it's a great idea to carry out a software delete now before confirming whether the EGRs are closing correctly.
I've got no basis for it, but there's a nagging doubt that if they're stuck open, it might cause some oddity to the exhaust system operation that might not be good long term. The worry is probably unfounded, as if they're mapped out, they will stop moving & shouldn't deteriorate further.
Before I remove the EGRs for inspection, has anyone removed faulty EGRs, cleaned them & regained successful operation ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #567998 25th Sep 2020 3:30pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey guys I'm looking to do this on my Overfinch but searching eBay i can only find the blanking kits for the tdv6 not the tdv8. Are they same ones you can use on the tdv8 or different? And they don't come with the shorter bolts. Be great if some of you good people on here could put me in the right direction? Thanks.
Post #592467 26th Apr 2021 7:03pm
