Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 |
I think he's hoping you guys will have an answer, from his video yesterday |
13th Apr 2021 2:58pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Sam, having watched your vids including your latest one, can I make a suggestion? Instead of making some gastly spare wheel holder for the rear! It would be far easier to cut the spare wheel well out and fabricate a central well (for the original compressor) weld in a flat floor and mount the spare wheel underneath a la Discovery 3 & 4... |
13th Apr 2021 11:07pm |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
I forgot to mention this, but one of the first things I did was the replace that rear accelerometer in the spare wheel well with a good used one - to no avail - however it might be worth revisiting. I know there are two more at the front, but they don't seem to be as easy to get to. Any ideas here?
I've not managed to do much more diagnostic work on it unfortunately, as my last couple of weekends have been taken up entirely with filming and editing a new project I might do an IID tool data log of a few bits - maybe height sensor voltage, plus damper current. I'll post it here so you guys can take a look. Any other suggestions of what to log? Thanks all! |
15th Apr 2021 7:55am |
Hmm... sounds like a decent idea, I'm just trying to picture if it would work. Wouldn't it be dropping down where the exhaust & back box sit currently? Also, I've always hated how you can see the spare wheel hanging down underneath the RRS / D3/D4 from behind. It probably isn't as much of a hindrance off-road as it looks though. |
15th Apr 2021 8:00am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 449 |
I don't think the IID can log damper current, it's been discussed on here before IIRC. I'm looking at building something that'll log x,y,z forces and damper current, but just haven't had the time recently. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) Last edited by D3Jon on 18th Apr 2021 6:02pm. Edited 1 time in total |
15th Apr 2021 2:32pm |
Ah I see. I can definitely log it using SDD, so that's a bit annoying they haven't implemented that in IID.
16th Apr 2021 7:48am |
I'd honestly think this functionality was available on the IID, I mean my old Nanocom can do it for a TD5!
20th Apr 2021 8:30pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
I have watched your vids and commented in the past as i have the same rear end harhsness issue, I really think the subframe busshes must be replaced ... if you think about it your shocks and suspension bushes can be as good as they want to be but the whole rear end they atatch too goes to the rest of the car via those four bushes except for the top of the struts right... (the 4 bushes known to be flogged at higher k's) ... so its just crazy not changing them
22nd Apr 2021 2:30pm |
The L322 definitely has headlight levelling if fitted with xenon’s, that despite also having self levelling suspension. When the driver’s side rear height sensor rod became detached on my 2002 FF, the Xenon's were pointing at the sky using their self levelling motors. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
22nd Apr 2021 7:08pm |
From the L322 workshop manual:
22nd Apr 2021 8:15pm |
23rd Apr 2021 2:02pm |
Actually (haha) The following taken from the 2010-2012 wm-
23rd Apr 2021 2:14pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2512 |
Static levelling is done by the air suspension but headlamps that turn also level during hard braking and hard acceleration. |
23rd Apr 2021 9:16pm |
So the cause of the hard riding issue may have shown itself today!
23rd Apr 2021 11:07pm |
