![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 44 ![]() ![]() ![]() |
I found a radar that seems like it could work but that part number is HPLA-9G768-AD. Link is below, Ive tracked down everything else the brakes, wiring, and steering wheel switch ill have to buy new. Can anyone confirm if this radar unit would work?
andyducati Member Since: 01 Sep 2017 Location: Eltham, Victoria Posts: 25 ![]() ![]() ![]() |
Yet Again, sorry for resurrecting this thread.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Could you list module status to see what shows for CCM-cruise control module so that it can be compared with mine?
Was that display from when about to do the reflash or now? It appears that the reflash hasn't yet been done. |
That was after the reflash. |
It appears to me to be stating that the reflash on the IIDtool is yet to be updated and therefore I would be re-attempting the update. |
Will have a check and re-flash the CCM.
Yes, I've encountered that situation myself. |
So I spent a bit of time with the car and re CCF to acc, put the fuse in and had the same fault come up. I performed the re flash on the module but no difference. I tried to calibrate using the IID but no change. I have no errors on the dash or any symbols relating to the cruise control. I then tried using the diagnostic computer from work (latest version of launchtech X431). I still get the error relating to instrument panel incorrect signal. I also tried to calibrate but because of the permanent fault the calibration fails.
I just checked my IID's display and mine is also showing New: CX23.. and New: BH32.. so that's not the problem.
Not enabling “Queue” just yet. Want to get normal ACC going first. Looks like your abs is a later version to mine probably as you have a later car (CA vin mine is BA vin). I may get an update for the instrument pack.
Is your pcm up to date? |
Finally got the ACC working and tested. After numerous emails to Patrick at GAP he came up with the solution. There are a few settings in the complete untested CCF page. One setting that I hadn’t seen.
