Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
Glad that you got it sorted! |
10th Apr 2021 2:31am |
The fat style radar unit is the left radar unit when 2 radar units are fitted, as applicable to the 3.6 TDV8 engine (MY10) and possibly early MY11 5.0 engines. It appears from Microcat 2012 that up to VIN BA334342 the left radar unit was sometimes fitted but the right radar unit LR029157 is applicable to all MY11/MY12 vehicles. Microcat 2012 also shows your dealer-referenced part is applicable to the MY13 L405 and I cannot find any reference to LR029157 superseding to the 2013 number.
25th Jun 2021 9:58pm |
Glide Member Since: 25 Jun 2021 Location: USA Posts: 7 |
Thanks for the reply. To further complicate things; yes it appears the fat-radar unit will fit on the right side of the vehicle but there is absolutely no wiring I can find on that side to accommodate it.
25th Jun 2021 11:12pm |
If you're referring to the right side when standing in front of the vehicle looking at it rather than when sitting in it then for that radar unit a link cable is required to run across to the main radar unit on the other side. I can't spot the link cable part number atm but I know that I've encountered it previously so I'll find it. |
25th Jun 2021 11:33pm |
If your vin is later than BA334342 then the fat, left side when sitting in the vehicle, radar unit isn't applicable, according to Microcat 2012. Do you know the vin of the supposedly 2012 vehicle from which the fat unit came? |
25th Jun 2021 11:56pm |
For clarity, my VIN is CA391XXX
26th Jun 2021 12:17am |
OK, we're on the same wavelength!
26th Jun 2021 12:29am |
Note that the same part is used in the 2010-13 RRS. |
26th Jun 2021 12:33am |
Awesome GraemeS. Thank you so much for the clarification.
26th Jun 2021 12:39am |
Any idea if part number FPLA-9G768-AC would work? It says it is for a 2013+ RRS Or can any unit with the 9G768 designation be used? I believe these exist in a lot of Ford vehicles and are far more plentiful (and cheaper) then RR parts. |
26th Jun 2021 12:45am |
That might be the number on one from a MY14 RRS built and sold in 2013 although I can't confirm the prefix. It wouldn't be recognised by your vehicle until its firmware was replaced with the BH32- version.
26th Jun 2021 12:51am |
Would anyone happen to have the part number for the slim-type radar mounting bracket?
3rd Jul 2021 3:03pm |
LR022947 |
3rd Jul 2021 8:56pm |
Thanks again GraemeS.
4th Jul 2021 2:55pm |
