Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 7 of 15 <123 ... 678 ... 131415>
jjfang
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
I found a radar that seems like it could work but that part number is HPLA-9G768-AD. Link is below, Ive tracked down everything else the brakes, wiring, and steering wheel switch ill have to buy new. Can anyone confirm if this radar unit would work?
https://www.ebay.com/itm/Genuine-Jaguar-La...3147139612
Post #579688 14th Jan 2021 4:03am
GraemeS
Australia
The HPLA prefix indicates that it is from a reasonably late model LR. If you have a GAP IIDtool then perhaps ask Gap if they can provide firmware to make it suitable for a MY12 L322, assuming that it is physically compatible.
Post #579691 14th Jan 2021 8:34am
andyducati
Australia 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
Yet Again, sorry for resurrecting this thread.
I'm still having problems getting ACC to work. I received a proper module the other week and fitted it. Its a CX23-9G768-AC. I also re-flashed it to the latest firmware for the module from Patrick at GAP.
I did the CCF changes and performed the Calibration function on my IID. I've driven the car around under various conditions but still have no cruise control. I have no errors showing on the dash, or any symbols or messages. Just nothing happens when I try to engage cruise.
I checked if any faults show in the IID and only 1 is persistent. it is
"U0423-81 (AF) Invalid data received from the instrument panel control module - Bus signal/message failure - invalid serial data received".
It also shows a time and date 4 years in the future and at 0km.
anyone have any ideas of this fault.
I CCF'd back to normal cruise and i now get the error of "cruise not available" on the dash and a couple of faults in the CCM and engine areas relating to lost communication with Cruise control module.
Post #589792 1st Apr 2021 3:43am
GraemeS
Australia
Could you list module status to see what shows for CCM-cruise control module so that it can be compared with mine?
CCM-Cruise Control (Latest Version) Assembly (F112) BH32-9G768-AD = Up-to-date Assembly (F113) CX23-9G768-AD -> BH32-9G768-AD Hardware (F111) BW83-14D047-AA = Up-to-date Serial 5612112760037 Signal (F108) BH32-14D048-AA = Up-to-date Signal (F120) BH32-14D049-BC = Up-to-date Strategy (F188) BH32-14D049-AD = Up-to-date
Do you have the engine bay fuse for the radar unit fitted when trying to get ACC to work and removed when trying to revert to normal CC?
When trying to get ACC to calibrate, do you see the instrument cluster icon indicating such?
Post #589811 1st Apr 2021 9:43am
andyducati
Yeh the fuse is in but I will double check it’s good. I don’t have any symbols on the dash at all.
I have works diagnostic computer for the weekend as well as my IID. I will do a bit more digging
Post #589863 1st Apr 2021 2:07pm
GraemeS
Australia
Was that display from when about to do the reflash or now? It appears that the reflash hasn't yet been done.
Post #589907 1st Apr 2021 8:53pm
andyducati
That was after the reflash.
Post #589933 2nd Apr 2021 3:20am
GraemeS
Australia
It appears to me to be stating that the reflash on the IIDtool is yet to be updated and therefore I would be re-attempting the update.
Post #589935 2nd Apr 2021 6:09am
andyducati
Will have a check and re-flash the CCM.
I took the fuse out and the normal cruise started working fine. So obviously theres a signal still coming from the CCM that messes with it and throws a fault in there.
Post #590062 3rd Apr 2021 3:16am
GraemeS
Australia
Yes, I've encountered that situation myself.
Post #590068 3rd Apr 2021 7:31am
andyducati
So I spent a bit of time with the car and re CCF to acc, put the fuse in and had the same fault come up. I performed the re flash on the module but no difference. I tried to calibrate using the IID but no change. I have no errors on the dash or any symbols relating to the cruise control. I then tried using the diagnostic computer from work (latest version of launchtech X431). I still get the error relating to instrument panel incorrect signal. I also tried to calibrate but because of the permanent fault the calibration fails.
I’ve sent an email to GAP, hopefully Patrick can figure it out and tell me how to fix it.
Post #590113 3rd Apr 2021 2:48pm
GraemeS
Australia
I just checked my IID's display and mine is also showing New: CX23.. and New: BH32.. so that's not the problem.
Here are screenshots of my settings.
https://www.fullfatrr.com/gallery/albums/u...-07-27.png
https://www.fullfatrr.com/gallery/albums/u...-07-36.png
Are you trying to enable stop and go? If so then the ABS module has to be at a particular level to support it.
Here's mine.
https://www.fullfatrr.com/gallery/albums/u...5B1%5D.png
Post #590158 3rd Apr 2021 10:22pm
andyducati
Not enabling “Queue” just yet. Want to get normal ACC going first. Looks like your abs is a later version to mine probably as you have a later car (CA vin mine is BA vin). I may get an update for the instrument pack.
Post #590173 4th Apr 2021 1:26am
GraemeS
Australia
Is your pcm up to date?
Post #590176 4th Apr 2021 3:12am
andyducati
Finally got the ACC working and tested. After numerous emails to Patrick at GAP he came up with the solution. There are a few settings in the complete untested CCF page. One setting that I hadn’t seen.
It was to enable ACC display in the instrument pack.
Enabled this and my fault disappeared, I was then able to do the align. It aligned after about 20 mins driving and it works a treat.
Thanks for all the help everyone especially GreameS.
Post #590766 10th Apr 2021 1:41am
