Home > Maintenance & Mods (L322) > IID switched extension lead |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I recall a thread but cannot find it..spent ages so no moaning at me
28th Mar 2021 8:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i'm pretty it was Mike [baltic blue] that talked about these...i cant find the thread either!!.. ... - .- -.
28th Mar 2021 10:19am |
It’s within a DPF one I think.....yes, Mike Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Mar 2021 11:24am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Mines not got a switch, but Greg installed one the same way with a switch.
28th Mar 2021 11:26am |
Any pictures so we can then maybe Wiki this idea? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Mar 2021 4:00pm |
I will take some snaps tomorrow and add to this thread, just opened a bottle of red
28th Mar 2021 4:04pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Easy to run it under the driver footwell trim. I broke one hinged OBD cover when it was hanging down and replaced it (I think it was more than £100!), so now I tuck it up out the way using blu-tac. It can't be seen.
28th Mar 2021 4:09pm |
29th Mar 2021 9:34am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Yes was me and mine is pretty much the same as RR L322 above.
29th Mar 2021 1:42pm |
I routed mine round and its completely hidden. Cable tied it and the IID to a round bar on the front of the seat frame. Used a small cork pad to mark the ON side so I can do everything by touch.
8th May 2021 7:18am |
I also cable tied the OBD door flap open via one of the vents in the kick panel Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th May 2021 7:19am |
Removed mine. It was not letting the iid read all the ecus for some reason. Back to manual insert mode Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Mar 2022 3:02pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Dr Rob - same here, removed mine. I suspect some of the cheaper extension leads do not connect to all the pins (also an issue with some scart extension leads). 2011MY 4.4TDV8 Autobiography Baltic Blue
5th Mar 2022 4:10pm |
Think you're right. It also stops me looking at too often Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Mar 2022 8:40pm |
