Home > Technical (L322) > Oil Flush before changing.
Chris1573
So planning to do oil change every 6k miles.
I have some Liqui Moly for flushing which according to the instructions you use 500ML per 5 L of sump capacity. So for a TDV8 3.6 I am assuming one litre.
Is it safe to add one litre of oil flush to the engine and then run it or do I need to drain a litre of oil out first so as not to overfill....? L322 2007 TDV8 3.6
Post #586754 9th Mar 2021 10:40am
ur20v
A Trap
I would not bother with oil flush, warm the engine, use a quality oil, changed regularly like you mentioned and at the most 6k miles.
If you block off your egr’s the oil will stay relatively clean after a couple of changes as well.
Post #586795 9th Mar 2021 2:58pm
Treebor99
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
I'm no expert, I just happen to work for a global engine manufacturer, some of my colleagues are pretty smart and have been around engines all their lives.
Alot of the engines we build run 24/7, 365 days a year. up to 95Litres and 4000hp.
This is what I've picked up from my technical colleagues over the years.
Modern detergent oils are designed to collect dirt which is then trapped in the oil filter.
As long as you are changing your oil on or before the due service interval all should be good.
No need to flush - I certainly don't flush my engines.
If a previous owner has not adhered to service schedule and the oil has become overloaded with dirt - no detergent left in the oil so it deposits dirt on ledges and dirt traps in your engine.
If you then flush that all out in one go, with an already end of life oil filter you could find the filter bypass opens due to a clogged filter - the result is all that dirty oil is circulated around all your bearings.
Also you just diluted the oil - thinner oil = thinner oil film for your bearings.
I'm not taking that risk - I don't flush my engines.
If you suspect a previous owner has gone over the service date the best thing you can do is just increase the oil change frequency, the detergents will pick up the dirt and trap it in the filter.
On another point, engine manufacturers have to test their engines to ensure they will survive, one of our tests is +10% max power & Torque.
There's an argument that people that drive their cars like they stole em have fewer problems than people who tootle about gently taking care of their engines. Would be fascinating to get data on that.
The engines were designed and tested for full power.
If I drive my FF like I stole it I won't have a license very long (but oh what fun!)
Used to always ride my motorbikes like I'd stolen them - never missed a beat.
Always warm an engine before working it hard - always always give turbos time to spool down and cool down.
Think how black baking trays go in the oven from baked on oil! that's what happens inside your turbo if you turn it off whilst it's very hot, the oil is burnt and turns to carbon, carbon is very bad for bearings.
These are just my observations and opinions formed over the last 35 years, they are not the thoughts of my employer.
 Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Current cars, 2011 FF 4.4 TVD8; Audit TT 1.8T convertible.
Post #586811 9th Mar 2021 6:00pm
Chris1573
So I checked the oil today... when I bought the RR 6 weeks ago I had it serviced at a local garage. I bought 20L of Castrol EDGE Professional C1 5W-30 and asked them to use this oil which they were happy to do. Since the oil change I have done about 500 miles. The oil is already black. I had to remove about 1.25 litres today as I found that the garage had overfilled it Neutral so I was able to see the colour.
I am not a fan of blocking off the EGRs I would rather put new ones on if I felt this was needed however the RR only has 73k on it and a full service history.
Looking back at the garage invoice I see that they did an engine oil flush when they changed the oil.
What should I expect to see after 500 miles, is black oil the norm ? L322 2007 TDV8 3.6
Post #587069 11th Mar 2021 5:51pm
dingg1
On diesels yes, black as black can be almost immediately after an oil change
Post #587071 11th Mar 2021 6:00pm
Merchy
Superb sound advice from Treebor. Should be required reading for anyone working on engines.
Engines we deal with range from truck sized units, then varying sizes of engines up to 40000 HP with 45000 litre sumps - all diesel engines, oil condition monitoring is obviously critical. I have only seen flushing used once in over 30 years, and that was due to VERY special circumstances.
Same as treebor, we run engine 24/7, longest diesel engine run I have ever seen was for 64 days from starting the engine to stopping.
Most engine builders would NEVER recommend using flushing oil, be it diesel or petrol.
Basically the mention of flushing oil gives me the heebie jeebies Big Cry
Post #587103 11th Mar 2021 8:56pm
dhallworth
I always baby my engines until they are warm, one of the reasons I like an oil and water temp gauge in my cars.
The FF’s at least have a water temp gauge which you can monitor, however, my 510bhp XFR doesn’t have a water or oil temperature gauge which is really annoying.
Once any of my cars are warmed up properly I’ve never had to change an EGR valve or anything but I do drive them properly once they’ve warmed up.
I’ve got a couple of friends who will use full power when cold and it makes me cringe.
I never use an engine flush either as am worried its thinning the oil whilst it works.
Post #587106 11th Mar 2021 9:12pm
Chris1573
I totally agree will be putting the Liqui Moly away and just doing the regular filter and oil changes Smile thanks guys.... L322 2007 TDV8 3.6
Post #587109 11th Mar 2021 9:21pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Exactly.
If u are worried do a 1000km oil changes a couple times..
I started doing this to auto transmission doing partial change.
It really affected positively. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #587220 12th Mar 2021 7:45pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i did the timing chains on mine and since then i have been draining the oil and changing the filter every tank full of petrol
i remove the sump plate every time
i have done it twice now and although the oil is perfectly clean looking, there has been a lot of rubbish in the sump RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #587439 14th Mar 2021 4:23pm
Chris1573
On a TDV8 3.6 Knares ? I did not think the timing chains on the 3.6 were an issue ? L322 2007 TDV8 3.6
Post #587449 14th Mar 2021 5:23pm
Bluegreygreen Rangie 2
Australia
Only if your not changing your oil / filter reguarly enough... Or in other words doing it when the manufacturer and or car itself says it,s time
My oil stays clean for 5 thouand k,s with ease!
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #587451 14th Mar 2021 5:50pm
evets
United Kingdom 2006 Range Rover HSE Td6 Java Black
EGRs should be changed 80,000 miles land rover / range rover use a french company called Valeo source Valeo direct half the price.
Post #587468 14th Mar 2021 8:33pm
knares
mine is not a TD6V8
i was thinking oil and filter changing is common to all engines RR 2005 4.4 petrol
Post #587497 15th Mar 2021 5:07am
Chris1573
Hi Knares, absolutely it was only the timing chain thing I was asking. L322 2007 TDV8 3.6
Post #587507 15th Mar 2021 9:19am
