![]() | Home > Technical (L322) > Oil Flush before changing. |
Naki Member Since: 04 Feb 2021 Location: Boston, South Lincolnshire Posts: 34 ![]() ![]() ![]() |
I bought my first TDV8 last week. I have just done an oil change on it. I found this feature very useful. Thanks for the info.
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Separate oil pan from turbos. To ensure oil drain from turbos in offroad conditions when car inclination is too big and regular pan oil level can be above the level of turbocharger. |
Great reply thanks. Very good information. 2007 L322 TDV8 3.6 Vogue SE
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 ![]() ![]() ![]() |
For the sake of a couple of quid on engine flush is it worth it?? |
Not worth it. Change the oil more regularly if you are worried about contamination or sludge. 2012 TDV8 Vogue (L322) |
Look at the discussion on page one. The answer to this question is covered in depth. 2007 L322 TDV8 3.6 Vogue SE
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
Regarding Engine flushes, below is a video from O Reillys mobile mechanic. He did an experiment where he did an oil change on a land rover and when he dipped the oil after it was still black. He then drained that new oil and it was black. Believe it or not but it took 5 oil changes before he started seeing gold colour.
Yes, thats true. I also tryed once, make 3 x oil change, it goes golder, but not compleatly.
