Home > Technical (L322) > Oil Flush before changing. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I would not bother with oil flush, warm the engine, use a quality oil, changed regularly like you mentioned and at the most 6k miles.
9th Mar 2021 1:58pm |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
I'm no expert, I just happen to work for a global engine manufacturer, some of my colleagues are pretty smart and have been around engines all their lives.
9th Mar 2021 5:00pm |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
So I checked the oil today... when I bought the RR 6 weeks ago I had it serviced at a local garage. I bought 20L of Castrol EDGE Professional C1 5W-30 and asked them to use this oil which they were happy to do. Since the oil change I have done about 500 miles. The oil is already black. I had to remove about 1.25 litres today as I found that the garage had overfilled it so I was able to see the colour.
11th Mar 2021 4:51pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
On diesels yes, black as black can be almost immediately after an oil change |
11th Mar 2021 5:00pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1182 |
Superb sound advice from Treebor. Should be required reading for anyone working on engines.
11th Mar 2021 7:56pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
I always baby my engines until they are warm, one of the reasons I like an oil and water temp gauge in my cars.
11th Mar 2021 8:12pm |
I totally agree will be putting the Liqui Moly away and just doing the regular filter and oil changes thanks guys.... L322 2007 TDV8 3.6 |
11th Mar 2021 8:21pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Exactly.
12th Mar 2021 6:45pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
i did the timing chains on mine and since then i have been draining the oil and changing the filter every tank full of petrol
14th Mar 2021 3:23pm |
On a TDV8 3.6 Knares ? I did not think the timing chains on the 3.6 were an issue ? L322 2007 TDV8 3.6 |
14th Mar 2021 4:23pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Only if your not changing your oil / filter reguarly enough... Or in other words doing it when the manufacturer and or car itself says it,s time My oil stays clean for 5 thouand k,s with ease! Dave 2010 3.6TDV8 Autobiography Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20 GAP Diagnostics Past - 02 & 03 TD6 And an 1984 Classic |
14th Mar 2021 4:50pm |
evets Member Since: 14 Mar 2021 Location: Manchester / Bolton Posts: 1 |
EGRs should be changed 80,000 miles land rover / range rover use a french company called Valeo source Valeo direct half the price. |
14th Mar 2021 7:33pm |
mine is not a TD6V8 i was thinking oil and filter changing is common to all engines RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
15th Mar 2021 4:07am |
Hi Knares, absolutely it was only the timing chain thing I was asking. L322 2007 TDV8 3.6 |
15th Mar 2021 8:19am |
