Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
So I would imagine, another reason to let it all settle a bit On tickover before you turn the engine off?
31st Jul 2020 12:54pm |
alfredlervaag Member Since: 18 Jun 2020 Location: krikane 5 6037 eidsnes Posts: 7 |
Hi,anyone have the partnumber on the fix mod line?
12th Sep 2020 3:01pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
LR045004 BMW i3 Electric Car
12th Sep 2020 3:22pm |
steve57060 Member Since: 03 Oct 2018 Location: Derby - Nottm Posts: 14 |
Looking at doing turbo drain mod to mine as it is used for towing so don't get chance very often to get revs up.
2nd Mar 2021 1:47pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 |
Just rev it above 2500rpm now and again by using the flappy paddles and save yourself a whole heap of effort and risk of swarf into the engine.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Mar 2021 2:00pm |
There is a risk to the DPF with the oil being dumped in there, dramatic soot rises on mine pre mod when it was smoking. Driving regularly above 2500 rpm isnt so easy due to the high gearing aqnd huge torque. BMW i3 Electric Car
2nd Mar 2021 2:08pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Steve from my research this is all sump work. You're not drilling the block.
2nd Mar 2021 2:10pm |
Never had any problems with dpf - no light ever
2nd Mar 2021 2:30pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 |
I don’t know by how much, but the subframe on mine was definitely loosened and moved when the drain mod was done by a MD. I could see where the Dinitrol coating had been disturbed.
2nd Mar 2021 3:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 |
i can confirm that Mike... ... - .- -.
2nd Mar 2021 4:14pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
Swarf is prevented from entering the sump by coating the drill bit with grease and removing the bit frequently to clean and renew the grease. The swarf feeds away from the rear of the cutting face so providing the bit isn't allowed to pull back then go forwards again without cleaning the bit and the drain to the lower hole then swarf should not get ahead of the tip. |
2nd Mar 2021 11:53pm |
Greg thanks for pic Noticed previous links to this mod that you were looking at getting yours done
3rd Mar 2021 12:17am |
3rd Mar 2021 10:33am |
Managed to find kit for mod LR045004 on ebay
3rd Mar 2021 10:34pm |
