![]() | Home > Maintenance & Mods (L322) > Battery conditioning how do you do it? |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Due to the lockdown I purchased a 28w solar panel and a cheap 12v MPPT charge controller, charges at a max of 5 amps. I am happy with the performance and have had no issues of the last 10 months. I used the CTEK battery plug and purchased another plug for the charge controller so I can easily swap between solar or CTEK.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Thanks everyone Ctek seems to be the answer. Have to save a few more pennies.! Was interested to see the hard wired one on I think the Sport forum with a hidden electric adapter in the back bumper. I would be worried about it blowing when the car was running.
Yep, definitely a bit sunnier here.
Jazzy Member Since: 29 Jan 2021 Location: Worcestershire Posts: 11 ![]() |
i've just got a smart charger with a cigarette lighter plug connected in the boot.
Kedgers Member Since: 22 Oct 2020 Location: Kings Langley Posts: 21 ![]() ![]() ![]() |
Hi there
What model do you have? L322 battery is under bonnet on passenger side . L405 I think has two batteries I am sure someone with better knowledge of them will be able to assist. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Many thanks
That sounds good to me! So does that stay connected permanently? a name of the product you have would be real useful or link to where you buy one please. thanks Rob |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
C-Tek 5 , plugged into 240v socket on the drive into 12v aux socket in boot 👍 |
Thanks everyone
Sorry missed this https://www.batterymegastore.co.uk/product...20533024r/ https://www.batterymegastore.co.uk/product...900300014/ |
thanks again!
Was in Aldi this morning and they had battery chargers in. £12.99 they are suitable for AGM batteries and can charge both 6 and 12 volt batteries. Model no is Auto XS MD 19787. Can charge at either 0.8 or 5 A and once fully charged goes to trickle charge mode 0.05 to 0.15 A.
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
CTEK MXS 7.0 plugged into the boot 12V aux sockets which is permanently live. Works well, the CTEK charging lead is small enough to go past the seal between the upper and lower tailrgate. This setup is in a garage.
