Home > LPG > 4.4 or 4.2sc |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Ahem one has a supercharger and better base specification and the other doesn’t. Why is this a question even? |
11th Feb 2021 9:07am |
fatladandy Member Since: 22 Jan 2017 Location: Winsford Posts: 10 |
My question was relating to which engine is better for LPG, I know the 4.4i is fine but i have no experience of the 4.2 sc engine either with or without lpg |
11th Feb 2021 9:25am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
I have a 4.2 on gas for 7 years now, I have slight petrol addition after 2900 rpm and valve saver, just a simple drip feed after throttle butterfly, done about 50k on gas no issues whatsoever.
11th Feb 2021 9:39am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 383 |
The 4.4 is easier to convert to LPG. The 4.2 requires the extra oil feed system for valve protection. Current:
11th Feb 2021 9:41am |
Aha LPG not just Gas as in Petrol
11th Feb 2021 10:20am |
11th Feb 2021 11:02am |
I do like the BMW engine and being a more simple installation it might be a diy job for me. I removed and refitted the LPG to my X5 when i had the headgasket and timing chains done. |
11th Feb 2021 11:32am |
I just want v8 goodness back in my life. Not especially concerned about economy. I currently have an M3 and civic type r so i am used to the bills but i can pick up a used LPG system and potentially diy fit so i might aswell save some cash. |
11th Feb 2021 11:34am |
You can do the conversion on the ajv8 without removing manifolds but it is a bit tricky, also you do need to fit a petrol return line with a suitable orifice installed to keep the fuelling correct, whether this is needed on the bmw lump I don't know. |
11th Feb 2021 11:52am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3133 |
Because the 4.4 is an engine which is perfectly suited to running on LPG, the 4.2 engine is a very different engine which suffers from softer valve seats and can lead to a £3-4k bill to have the issue remedied. What's the problem with someone seeking advice? The early 5.0's are a flawed engine as well and in many ways the 4.2 is far better from a reliability point of view. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
11th Feb 2021 2:31pm |
