![]() | Home > LPG > 4.4 or 4.2sc |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Ahem one has a supercharger and better base specification and the other doesn’t. Why is this a question even? |
fatladandy Member Since: 22 Jan 2017 Location: Winsford Posts: 10 ![]() ![]() |
My question was relating to which engine is better for LPG, I know the 4.4i is fine but i have no experience of the 4.2 sc engine either with or without lpg |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
I have a 4.2 on gas for 7 years now, I have slight petrol addition after 2900 rpm and valve saver, just a simple drip feed after throttle butterfly, done about 50k on gas no issues whatsoever.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 394 ![]() ![]() ![]() |
The 4.4 is easier to convert to LPG. The 4.2 requires the extra oil feed system for valve protection. Current:
Aha LPG not just Gas as in Petrol |
I do like the BMW engine and being a more simple installation it might be a diy job for me. I removed and refitted the LPG to my X5 when i had the headgasket and timing chains done. |
I just want v8 goodness back in my life. Not especially concerned about economy. I currently have an M3 and civic type r so i am used to the bills but i can pick up a used LPG system and potentially diy fit so i might aswell save some cash. |
You can do the conversion on the ajv8 without removing manifolds but it is a bit tricky, also you do need to fit a petrol return line with a suitable orifice installed to keep the fuelling correct, whether this is needed on the bmw lump I don't know. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Because the 4.4 is an engine which is perfectly suited to running on LPG, the 4.2 engine is a very different engine which suffers from softer valve seats and can lead to a £3-4k bill to have the issue remedied. What's the problem with someone seeking advice? The early 5.0's are a flawed engine as well and in many ways the 4.2 is far better from a reliability point of view. ![]() 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
