Home > LPG > 4.4 or 4.2sc
fatladandy
4.4 or 4.2sc
I am currently looking to get myself an L322. I am undecided on which engine to go for. I have a budget in mind that would see me in either a 4.4i or 4.2 sc. I have previously had the 4.4 engine on gas in an x5 and that ran brilliantly however i have no experience or knowledge of the 4.2 sc when running gas.
Which engine would be the best option to go for.
Thanks
Post #583212 11th Feb 2021 9:40am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Ahem one has a supercharger and better base specification and the other doesn’t. Why is this a question even?
Post #583218 11th Feb 2021 10:07am
fatladandy
My question was relating to which engine is better for LPG, I know the 4.4i is fine but i have no experience of the 4.2 sc engine either with or without lpg
Post #583221 11th Feb 2021 10:25am
dingg1
I have a 4.2 on gas for 7 years now, I have slight petrol addition after 2900 rpm and valve saver, just a simple drip feed after throttle butterfly, done about 50k on gas no issues whatsoever.
The bmw engine has harder seats and is better for lpg though.
Post #583222 11th Feb 2021 10:39am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
The 4.4 is easier to convert to LPG. The 4.2 requires the extra oil feed system for valve protection. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #583223 11th Feb 2021 10:41am
Bl4ckD0g
Aha LPG not just Gas as in Petrol Wink
Anyway as I said one has a super charger and a lot more horsepower and a better base specification. Why is this a question 🤣
Either will be fine if the installer is good. Personally I wouldn’t bother with it. If fuel economy is an issue then one may as well get the diesel. Those petrol engines aren’t ULEZ compliant anyway, so won’t have that benefit either. Both engine models are quite old now, and cheap to buy. But does it make sense to spend the money to add LPG to them at that age? You can buy a lot of fuel for the cost of an installation.
Post #583229 11th Feb 2021 11:20am
dingg1
Rolling Eyes
Post #583235 11th Feb 2021 12:02pm
fatladandy
I do like the BMW engine and being a more simple installation it might be a diy job for me. I removed and refitted the LPG to my X5 when i had the headgasket and timing chains done.
Post #583237 11th Feb 2021 12:32pm
fatladandy
I just want v8 goodness back in my life. Not especially concerned about economy. I currently have an M3 and civic type r so i am used to the bills but i can pick up a used LPG system and potentially diy fit so i might aswell save some cash.
Post #583239 11th Feb 2021 12:34pm
dingg1
You can do the conversion on the ajv8 without removing manifolds but it is a bit tricky, also you do need to fit a petrol return line with a suitable orifice installed to keep the fuelling correct, whether this is needed on the bmw lump I don't know.
Post #583240 11th Feb 2021 12:52pm
dhallworth
Because the 4.4 is an engine which is perfectly suited to running on LPG, the 4.2 engine is a very different engine which suffers from softer valve seats and can lead to a £3-4k bill to have the issue remedied.
What's the problem with someone seeking advice? The early 5.0's are a flawed engine as well and in many ways the 4.2 is far better from a reliability point of view. Rolling Eyes 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #583263 11th Feb 2021 3:31pm
