Home > Maintenance & Mods (L322) > Whining noise with revs 2011 4.4 TDV8 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 334 |
Does it change pitch with revs or with speed?
5th Feb 2021 10:36am |
Blitzsah Member Since: 13 Dec 2020 Location: Warwickshire Posts: 23 |
I will get a video on way home tonight. Personally I think it could be the torque converter starting to fail but I have no way of verifying this so I guess it will be a trip to a gearbox specialist.
5th Feb 2021 11:57am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3130 |
transfer box? |
5th Feb 2021 12:19pm |
LT Member Since: 13 Mar 2017 Location: South West Posts: 396 |
Similar to this noise?:
5th Feb 2021 1:10pm |
That could even be the alternator? Maybe also check low range versus high range, see if that affects it. Perhaps also check some of the 4wd modes (grass/gravel/slow) to lock the diff and see if that has any affect... |
5th Feb 2021 1:21pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6716 |
Could very well be signs of an impending alternator failure
5th Feb 2021 1:31pm |
Thanks for that link, it’s actually very similar to that noise!! Was hoping there was a root cause near the end of the thread but it seems you’re yet to fix this issue I agree it could be alternator on its way out too. I just don’t want to start replacing things to not fix the problem as it’s going to get very costly. I’m tempted to just leave it and see if it gets any worse. Although it is annoying!! |
5th Feb 2021 1:54pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
I'm not sure of the location of the alternator but is it possible to get a long screwdriver pressed against the alternator and then press your ear on the handle and you should be able to hear if the alternator is noisy or not 2011 TDV8 Vogue SE |
5th Feb 2021 1:58pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I find the whining noise that increases with revs and speed is the the wife, solution is to remove wife and drive alone or drive very slowly keeping revs down.
5th Feb 2021 4:46pm |
https://vimeo.com/508973090
5th Feb 2021 9:58pm |
Hmm, there's something, but I'm not sure I'd have noticed it if you'd not pointed it out, to be honest!
6th Feb 2021 11:45am |
I think maybe I’m wanting a noise to be there and therefore hearing it more? Maybe it is just the normal cabin noise, I don’t know. I think I will wait and see if I notice any change in the noise before going any further, it is really quiet |
6th Feb 2021 2:37pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 472 |
I started to hear a whining noise and ignored it for a while. As I started to think about it more I began monitoring the vehicle signals in the hidden menu, specifically the battery voltage reading which became more and more erratic and was nowhere near the voltage it should have been.
6th Feb 2021 5:07pm |
Hi Chris, thanks for info do you know if the hidden menu is accessible on 12MY? What steps do I need to take to access it?
6th Feb 2021 5:15pm |
