Home > Maintenance & Mods (L322) > Whining noise with revs 2011 4.4 TDV8
Blitzsah
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Hi all,
I’m getting a whining noise that changes pitch with revs. If I put the car into neutral when moving the noise disappears. It’s not very loud but definitely noticeable even with the radio on. I would say it is most noticeable when slowing down at around 30mph or so, probably because the revs are masking the noise? It definitely sounds as if it’s coming from gearbox area. If I’m sat on the drive at home and Rev the engine I can’t really hear anything from outside the car, it’s more noticeable inside the cabin.
I took it to my local specialist and they said there was a leak from the gearbox so they have changed the sump, filter and oil and then they gave the car back to me saying the noise is fixed.
Well it definitely isn’t fixed as the noise is exactly the same. Before I go back to garage I wanted to get a few opinions on here as to what I can check at home. Also don’t want to take it back to this garage really so has anyone got any recommendations for specialists around the Rugby area?
Post #582441 5th Feb 2021 10:00am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Does it change pitch with revs or with speed?
You say revs, but then you say it disappears when it goes into neutral - if you're in neutral and rev the engine does the whine still change in-line with the revs?
Might be helpful if you take a quick recording with your phone and link it here, so we can have a listen! Smile
Post #582454 5th Feb 2021 11:36am
Blitzsah
I will get a video on way home tonight. Personally I think it could be the torque converter starting to fail but I have no way of verifying this so I guess it will be a trip to a gearbox specialist.
If I’m going along in neutral and Rev the engine then the whine is still present but it’s a lot quieter. I would say the noise is most noticeable on deceleration at low speed in gear.
Post #582474 5th Feb 2021 12:57pm
Dolphinboy
transfer box?
Post #582480 5th Feb 2021 1:19pm
LT
Similar to this noise?:
https://www.fullfatrr.com/forum/topic55105.html
Post #582483 5th Feb 2021 2:10pm
Siftah
That could even be the alternator?
Maybe also check low range versus high range, see if that affects it.
Perhaps also check some of the 4wd modes (grass/gravel/slow) to lock the diff and see if that has any affect...
Post #582487 5th Feb 2021 2:21pm
Could very well be signs of an impending alternator failure Rolling Eyes
Rather strangely, when mine failed, I could hear the noise inside but not outside the car............ Got - 2017 SDV8 Autobiography in Loire Blue
Post #582491 5th Feb 2021 2:31pm
Blitzsah
Thanks for that link, it’s actually very similar to that noise!! Was hoping there was a root cause near the end of the thread but it seems you’re yet to fix this issue Sad
I agree it could be alternator on its way out too. I just don’t want to start replacing things to not fix the problem as it’s going to get very costly. I’m tempted to just leave it and see if it gets any worse. Although it is annoying!!
Post #582495 5th Feb 2021 2:54pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I'm not sure of the location of the alternator but is it possible to get a long screwdriver pressed against the alternator and then press your ear on the handle and you should be able to hear if the alternator is noisy or not 2011 TDV8 Vogue SE
Post #582497 5th Feb 2021 2:58pm
ur20v
A Trap
I find the whining noise that increases with revs and speed is the the wife, solution is to remove wife and drive alone or drive very slowly keeping revs down.
Seriously though, Remove the drive belt and see if the noise goes, will remove a lot of possibles and narrow down the search. Alternator is favorite but idlers, tensioner and water pump could make a whine. Once the belt is off check for any play in the pulleys and rough or tight running, then start the engine and try and replicate the noise, everything will be OK for a short couple of minute rev or drive.
Post #582510 5th Feb 2021 5:46pm
Blitzsah
https://vimeo.com/508973090
Video at link above. Someone tell me I’m not going mad
Post #582536 5th Feb 2021 10:58pm
Siftah
Hmm, there's something, but I'm not sure I'd have noticed it if you'd not pointed it out, to be honest!
I couldn't even swear to mine not sounding the same honestly :\
Post #582567 6th Feb 2021 12:45pm
Blitzsah
I think maybe I’m wanting a noise to be there and therefore hearing it more? Maybe it is just the normal cabin noise, I don’t know. I think I will wait and see if I notice any change in the noise before going any further, it is really quiet
Post #582591 6th Feb 2021 3:37pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I started to hear a whining noise and ignored it for a while. As I started to think about it more I began monitoring the vehicle signals in the hidden menu, specifically the battery voltage reading which became more and more erratic and was nowhere near the voltage it should have been.
Obviously I ignored it for too long and ended up being brought home by the RAC when the alternator threw in the towel.
If it’s worrying you, check the voltage; it may be ok but it also might give you a heads up if the alternator is starting to die Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #582604 6th Feb 2021 6:07pm
Blitzsah
Hi Chris, thanks for info do you know if the hidden menu is accessible on 12MY? What steps do I need to take to access it?
Cheers
Post #582605 6th Feb 2021 6:15pm
