Home > Maintenance & Mods (L322) > Whining noise with revs 2011 4.4 TDV8
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
It should be the same as mine.
Press home then touch the top centre of the screen for 5 or 6 seconds. Then press and hold the hard navigation button for a few seconds and a number pad should appear. Enter 753 then you should have the menu - vehicle signals is second down on the right on mine. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #582610 6th Feb 2021 5:56pm
Blitzsah
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
After the drive to work this morning I thought I would check out the battery voltage, it was reading between 14.5-14.7 when I was idling in the car park. Maybe a little high?
I will keep the monitor on for the trip home and see if there’s much change.
Post #582792 8th Feb 2021 10:29am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
For an AGM battery that's about right - it varies with the temperature and the batteries state of charge as to how much the ECU will determine to put into it, but the AGM's take a higher charging voltage than non-AGM batteries do.
Post #582810 8th Feb 2021 12:41pm
