![]() | Home > Maintenance & Mods (L322) > Dead Battery |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 ![]() ![]() ![]() |
That’s good news then. I’ve needed a new one on mine for ages, but as it’s not being used much now, and inside, it’s just sat on the trickle charger.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 ![]() ![]() ![]() |
ECP are renowned for offering all sort of "deal discounts" but only after they inflate the price to start with |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Mine tends to use a battery every 2 years.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
Halfords AGM battery with 5 year warranty about £180 - easy exchange if it goes faulty. 2010 VSE [Roger] |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Mine has not gone yet but i think it could be better.
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
I just switched out a 12 month old Lion battery (previous owner) after it started to struggle in the winter. Big difference in starting speed and less worry about it going flat after half an hour with the doors open. 2008/58 FFRR 3.6 TDV8 Vogue |
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 ![]() ![]() ![]() |
Well I guess I didn’t do too badly then.The battery I switched out was a LANDROVER branded Varta battery dated 2012 so guessing the original that the car came from the dealership with. 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 209 ![]() ![]() ![]() |
Changed mine end of December. Was still the original JLR/Varta battery dated 2011. Changed it for a Varta G14, which is the same battery as original. £160 with discount from Tayna. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
Having been bitten (again) recently by Euro Crap Parts it saddens me that they use nonsense to convince people that they are getting a bargain.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 ![]() ![]() ![]() |
Okay, so battery completely dead. I am trying to jumpstart. Got the second car connected up with substantial leads. Second car is running.
run a multimeter on the dead battery while the jump leads are connected. see if you get anything.
Battery recharged & car running after some shenanigans; anyone know what this connector is on the bulkhead behind the positive terminal ?
Is that an AGM battery? |
No, unfortunately not. An AGM is winging it’s way through the courier network right now. TDV8 4.4 2012 |
