Home > Maintenance & Mods (L322) > Dead Battery
JayGee
Ramblin Man wrote:
Battery recharged & car running after some shenanigans; anyone know what this connector is on the bulkhead behind the positive terminal ?
It's used by the dealer to prevent battery drain when in the showroom or during transportation so don't connect it. 2012 TDV8 Vogue (L322)
Post #652223 1st Jan 2023 11:18am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
That sounds handy, how/where do you connect it?
Quite a few of us could probably make use of that! Smile
Post #652240 1st Jan 2023 2:02pm
JayGee
AFAIK it's part of a set of protocols and other kit for dealer use so it should be left alone / has no benefit for the customer. If you download the workshop manual from the Wiki it explains it's function better than I can. 2012 TDV8 Vogue (L322)
Post #652242 1st Jan 2023 2:57pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
@JayGee; Thank you ! There’s one or two odd wires around that I’m finding & I’m trying to find out what each is. TDV8 4.4 2012
Post #652243 1st Jan 2023 3:08pm
