![]() | Home > Technical (L322) > L322 4.4 TDV8. Starter Motor doesn't always engage when cold |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Have a search on here, there is a sometimes problem with the starter and they do fail on occasion. There is nothing that can't be fixed with a hammer😜😜
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
The solenoid is part of the starter issues normally revolve around the main feed in the solenoid getting sooted up/burnt. I had to replace mine at 80k. I don’t think you can detach the solenoid with the starter in place..... 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I’ve had a new battery and starter and still get this issue. It can not do it for a few days, then sometimes once, sometimes four times, hot or cold. Occasionally I get the click then 2 seconds later it starts.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
In cold weather the load on the starter will increase which in turn puts a load on the connections. Have you checked the battery connections? If not properly pushed on and tightened the symptoms you describe are one possibility. John
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Battery to starter lead is apparently made up of 4 different sections plus a fuse can get dirty...just what I’ve read on here. Search using starter+motor in the search box function |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I have a similar issue on mine!! cannot make my mind up if the starter is failing or bad connection or the push button has an issue. i can go days with no issues then it will play up then nothing.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
I am not a gambling man, but I would put my money on the starter motor to go first.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
I would also suggest you're going to have to replace the starter motor.
I agree it will but it is not clicking often enough yet |
I waited for a nice warm day then changed it.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
There must be a reason the same starter motor contacts burn out on the 4.4, but not the 3.6... |
What we all really need is some sort of anti spark grease to put on the copper contacts and prevent arcing burn.
Sounds more like high resistance developing somewhere in the starter feed. |
Both Mpirie Mike and myself stripped failed motors and were gobsmacked by how badly burned the contacts were.
