Home > Technical (L322) > L322 4.4 TDV8. Starter Motor doesn't always engage when cold |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
They are chunky enough to re-face if you have access to a lathe.
20th Jan 2021 8:24am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Check that the battery terminals are clean and can be tightened firmly on the posts. |
25th Feb 2022 7:36pm |
Quarryman Member Since: 20 Feb 2022 Location: Wiltshire Posts: 9 |
Yes - the battery was disconnected for starter replacement and checked for good contact. Everything is clean and the battery is 3 months old. I also connected another running vehicle with heavy jump leads to the terminals under the bonnet, and still had a couple of clicks before the starter turned so I assume the battery connections must be OK? Obviously the connection to the starter has been off and re-connected and that end is OK too. I did read somewhere that the cable may have some connections in it such as a fuse (on an L322 anyway) that may be a cause of high resistance, but I have no idea where this would be on mine or where to start looking,
26th Feb 2022 5:10am |
