Home > Technical (L322) > L322 4.4 TDV8. Starter Motor doesn't always engage when cold
Page 1 of 3 123>
jackconcord
When I try to start the car when cold, I sometimes just get a 'click' noise & starter doesn't engage. After a couple more attempts, it starts as normal.
I fitted a new battery 12 months ago & keep it on a CTEK trickle charger when not in use, so battery is always fully charged.
I wander if it could be a problem with the solenoid.
Has anyone had a similar experience?
Post #580142 17th Jan 2021 6:14pm
Have a search on here, there is a sometimes problem with the starter and they do fail on occasion. There is nothing that can't be fixed with a hammer😜😜
Post #580144 17th Jan 2021 6:19pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
The solenoid is part of the starter issues normally revolve around the main feed in the solenoid getting sooted up/burnt. I had to replace mine at 80k. I don’t think you can detach the solenoid with the starter in place..... 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #580147 17th Jan 2021 6:36pm
coopss
I’ve had a new battery and starter and still get this issue. It can not do it for a few days, then sometimes once, sometimes four times, hot or cold. Occasionally I get the click then 2 seconds later it starts.
I read a post on here about a cable getting brittle but can’t recall the detail 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #580149 17th Jan 2021 6:45pm
Weegie
In cold weather the load on the starter will increase which in turn puts a load on the connections. Have you checked the battery connections? If not properly pushed on and tightened the symptoms you describe are one possibility. John
GAP iiD BT-Sold
Post #580153 17th Jan 2021 7:33pm
DrRob
Battery to starter lead is apparently made up of 4 different sections plus a fuse can get dirty...just what I’ve read on here. Search using starter+motor in the search box function Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #580176 17th Jan 2021 10:11pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I have a similar issue on mine!! cannot make my mind up if the starter is failing or bad connection or the push button has an issue. i can go days with no issues then it will play up then nothing.
I have opted to wait until something fails rather than randomly replace bits. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #580204 18th Jan 2021 10:12am
Baltic Blue
I am not a gambling man, but I would put my money on the starter motor to go first.
So many owners have replaced them and had no further issues.
Post #580205 18th Jan 2021 10:25am
mpirie
I would also suggest you're going to have to replace the starter motor.
There's a great write-up in the wiki that highlights the symptoms as well as the replacement process if you're handy with spanners.
Mike
Post #580210 18th Jan 2021 11:03am
Jayk69
I agree it will but it is not clicking often enough yet Mr. Green though now i have said that it will pack up completely Big Cry Rolling with laughter 2012 Vogue 4.4 TDV8 - Current
Post #580221 18th Jan 2021 11:53am
Baltic Blue
I waited for a nice warm day then changed it.
Nearly 2 years ago now, but “ touch wood “ been fine since.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #580230 18th Jan 2021 12:56pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
There must be a reason the same starter motor contacts burn out on the 4.4, but not the 3.6...
Post #580259 18th Jan 2021 3:50pm
Baltic Blue
What we all really need is some sort of anti spark grease to put on the copper contacts and prevent arcing burn.
They use something similar to silicon grease on high voltage switchgear to stop similar problems, but I can’t find any.
Post #580262 18th Jan 2021 4:23pm
Philip
Sounds more like high resistance developing somewhere in the starter feed.
Post #580281 18th Jan 2021 5:03pm
Baltic Blue
Both Mpirie Mike and myself stripped failed motors and were gobsmacked by how badly burned the contacts were.
We both fitted new starters and refurbished the old one ready for next time.
Post #580284 18th Jan 2021 5:12pm
Page 1 of 3 123>
