Home > Technical (L322) > Normal height only error message |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Suspect is the sensors.. have you check for any fault codes? Current:
7th Dec 2020 12:26am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
My L322 gave this message when the compressor was u/s, it seems to get triggered if the compressor runs for a long time to maintain / build up pressure. Try drilling out the filter as described elsewhere on here. BMW i3 Electric Car
7th Dec 2020 5:14am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
+1 compressor |
7th Dec 2020 11:20am |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 |
Hey guys, some news
12th Jan 2021 9:47pm |
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 |
Compressor is repairable on later cars, there are filter kits and seal kits to replace worn parts usually around £60 just search the internet
13th Jan 2021 1:29pm |
mandelbug Member Since: 06 Mar 2017 Location: London Posts: 40 |
I bought a repair kit for mine, went to fit it and found the conrod had snapped and the conrod/piston were in about 6 pieces. Ended up replacing the whole unit. Easily done (4 bolts holding it down, couple of connectors) |
13th Jan 2021 1:34pm |
