Home > Technical (L322) > No heater fan - FSR? |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
following my previous post about final stage resistor I may also require a replacement fan.
28th Dec 2020 3:30pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Pull the fuse in the boot for the main blower fan. F21 I think it is. That will stop battery going flat while you await the new FSR. Be warned that some cheap FSR fail prematurely from what I've read. A Genuine one from Duckworth's is about £40 I think. I might be way out though...
28th Dec 2020 4:11pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Try the FSR first to see if it solves the problem because changing the main fan is a lot of work!
28th Dec 2020 7:26pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 360 |
I fitted a Merle 64 11 6 923 604
28th Dec 2020 8:04pm |
https://www.ebay.co.uk/itm/FOR-BMW-3-5-SER...SwLYRbT2hw
28th Dec 2020 8:09pm |
[quote="DrRob"
28th Dec 2020 8:38pm |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 |
If yours is still using JGO000021 then I gave 51 quid for a genuine one from LR
28th Dec 2020 9:16pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 803 |
Is the fan blower still providing air to the rear?
29th Dec 2020 6:44am |
does anyone have a definitive fuse number for the fan on 2010 VSE? or where I can find this information?
29th Dec 2020 9:56am |
ok, found the wiring diagram and *I think* identified the relevant fuse (#21 in the rear right side junction box) but when I take that fuse out and stick the ammeter across the pins that the fuse would normally bridge, there's no current flowing
29th Dec 2020 11:06am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
If an fsr fails it usually results in the blower fan only running on full speed only. |
29th Dec 2020 11:17am |
F21 in boot is for the front fan only I believe. There is a separate one for the rear fan: F14 in boot IIRC (a blue 15A) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Dec 2020 11:34am |
FSR has arrived!
1st Jan 2021 1:46pm |
Did one on my 2012 about 18 months ago...90% certain it is a clip no screws as it’s a very tight fit for access will confirm in morning as I have old one in garage 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
1st Jan 2021 8:34pm |
