Home > Technical (L322) > No heater fan - FSR?
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
2010 VSE
its been 4 days since the heater fan stopped working. all lights on the switches relating to the heater / air con illuminate correctly when they're twiddled yet nothing will cause the fan to run.
I ordered an FSR from ebay with the intention of replacing when it arrived (est. 5th Jan 2021 from listing)
However, this morning the battery was flat (its a good battery and alternator) so that seems to show that I also have a battery drain issue which seems to be consistent with typical FSR fault (though could still also be a faulty fan motor).
Pending arrival of the replacement FSR is it ok to unplug the cable from it to avoid further battery drain?
Post #577501 28th Dec 2020 3:21pm
dexion7
following my previous post about final stage resistor I may also require a replacement fan.
looking at the options on ebay there seems to be unbranded for £30, Febi 38482 at around £65 or genuine for um... £190.
Does anyone have any experience of either or should I buy genuine?
Post #577503 28th Dec 2020 3:30pm
DrRob
Pull the fuse in the boot for the main blower fan. F21 I think it is. That will stop battery going flat while you await the new FSR. Be warned that some cheap FSR fail prematurely from what I've read. A Genuine one from Duckworth's is about £40 I think. I might be way out though...
Why blower motor needed? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577524 28th Dec 2020 4:11pm
mpirie
Try the FSR first to see if it solves the problem because changing the main fan is a lot of work!
Mike
Post #577554 28th Dec 2020 7:26pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I fitted a Merle 64 11 6 923 604
https://www.ebay.co.uk/itm/273722108774?ul...noapp=true
£34 none available from where I bought it but a search may find one. My RR is 2012 4.4 tdv8. Hope this helps 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #577555 28th Dec 2020 8:04pm
V8 Bob
https://www.ebay.co.uk/itm/FOR-BMW-3-5-SER...SwLYRbT2hw
This is the one I got still got box! And still working fine......... 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #577557 28th Dec 2020 8:09pm
dexion7
[quote="DrRob"
Why blower motor needed?[/quote]
i read on another thread of here that in some case the FSR fails because the fan bearings have gone tight which results in the motor drawing a higher current than usual which overloads the FSR.
thanks for the help guys I'll try the fuse until the FSR arrives
Post #577561 28th Dec 2020 8:38pm
Ian G
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
If yours is still using JGO000021 then I gave 51 quid for a genuine one from LR
Fan fuse was number 64 in the glove box for me but mine is an older one, 2003. I suspect yours is different but maybe this might help someone in future who finds this thread in Google with an older car Smile
Blower motor is a sound shout as the contributory failure but unless you kill a few resistors I probably wouldn't do it preventatively, rather large job so to be avoided unless absolutely necessary.
Post #577567 28th Dec 2020 9:16pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Is the fan blower still providing air to the rear?
Manual says fan blower is a 10 hour job.
So you really want to be sure the fan blower needs changing.
Post #577607 29th Dec 2020 6:44am
dexion7
does anyone have a definitive fuse number for the fan on 2010 VSE? or where I can find this information?
Rambles: the wiki on this forum shows a short cut which then makes it a 3 hour job which sounds much better
Post #577623 29th Dec 2020 9:56am
dexion7
ok, found the wiring diagram and *I think* identified the relevant fuse (#21 in the rear right side junction box) but when I take that fuse out and stick the ammeter across the pins that the fuse would normally bridge, there's no current flowing Confused
the rear heater fan continues to work fine.
any further info appreciated
Post #577631 29th Dec 2020 11:06am
If an fsr fails it usually results in the blower fan only running on full speed only. Thumbs Up
Post #577632 29th Dec 2020 11:17am
DrRob
F21 in boot is for the front fan only I believe. There is a separate one for the rear fan: F14 in boot IIRC (a blue 15A) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577638 29th Dec 2020 11:34am
dexion7
FSR has arrived!
following the wiki on here and the vids on you tube, I'm still not clear on a few things:
1) I've removed the flat, horizontal plastic panel which has the very large plastic screw thing at the rear and holds the ODB connector and footwell lamp.
2) after 5 minutes of looking finally saw the FSR (actually recognised the colours of the wires going to it and eventually saw it with a mirror) and also removed the connector of the FSR.
3) access to FSR is restricted by the horizontal air duct and that doesn't seem to be removable without first removing the trim panel below the steering column and to remove that trim panel is seems that the dash end finishers (piano black) must first be removed. Powerful Uk have a video to show how to remove those but that video does not relate to 2010 VSE cars!!
4) various posts on here and elsewhere state that there is a clip and then just pull the FSR out but on you tube vids the FSR is held in on its 2 mounting holes by torx screws?
anyone who's done this on a 2010 can help please? 2010 VSE [Roger]
Post #577975 1st Jan 2021 1:46pm
V8 Bob
Did one on my 2012 about 18 months ago...90% certain it is a clip no screws as it’s a very tight fit for access will confirm in morning as I have old one in garage 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #578030 1st Jan 2021 8:34pm
