![]() | Home > Technical (L322) > No heater fan - FSR? |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
following my previous post about final stage resistor I may also require a replacement fan.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Pull the fuse in the boot for the main blower fan. F21 I think it is. That will stop battery going flat while you await the new FSR. Be warned that some cheap FSR fail prematurely from what I've read. A Genuine one from Duckworth's is about £40 I think. I might be way out though...
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 905 ![]() ![]() ![]() |
Try the FSR first to see if it solves the problem because changing the main fan is a lot of work!
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
I fitted a Merle 64 11 6 923 604
https://www.ebay.co.uk/itm/FOR-BMW-3-5-SER...SwLYRbT2hw
[quote="DrRob"
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 ![]() ![]() ![]() |
If yours is still using JGO000021 then I gave 51 quid for a genuine one from LR
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Is the fan blower still providing air to the rear?
does anyone have a definitive fuse number for the fan on 2010 VSE? or where I can find this information?
ok, found the wiring diagram and *I think* identified the relevant fuse (#21 in the rear right side junction box) but when I take that fuse out and stick the ammeter across the pins that the fuse would normally bridge, there's no current flowing |
If an fsr fails it usually results in the blower fan only running on full speed only. |
F21 in boot is for the front fan only I believe. There is a separate one for the rear fan: F14 in boot IIRC (a blue 15A) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
FSR has arrived!
Did one on my 2012 about 18 months ago...90% certain it is a clip no screws as it’s a very tight fit for access will confirm in morning as I have old one in garage 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
