Home > Technical (L322) > No heater fan - FSR?
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
hi Bob,
I'm not sure if looking at an FSR will help to determine this since they seem to look the same irrespective of the securing method as they have 2 holes which could accommodate screws or simply use the holes to align on something and then the screws or a clip holds FSR in place. I cant see a clip on mine but its difficult to see the thing anyway!
how did you improve access to it? 2010 VSE [Roger]
Post #578044 1st Jan 2021 10:18pm
V8 Bob
If I remember correctly took of side panel on centre console then undid 4 screws holding panel below steering wheel and pulled to one side. I’ve got small hands so managed to get up under dash to unplug and release the old unit. Was a tight squeeze if I remember correctly and as such pretty certain there were no screws to remove or refit. Was a right pain to be honest. I would ensure seat as far back as possible and steering wheel up as high as possible. Will try and find utube video I followed. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #578046 1st Jan 2021 10:23pm
V8 Bob
https://www.google.co.uk/url?sa=t&rct=...YMAQef6aEk
Think this is the one but I can’t remember taking out the ventilation duct! Two holes on FSR fit over pins . Hope this helps 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #578048 1st Jan 2021 10:43pm
dexion7
well the heater duct is removed at 4.30 in that vid. cant see how to get the duct out and cant get access with it left in place! 2010 VSE [Roger]
Post #578067 2nd Jan 2021 10:22am
DrRob
It's in the Workshop Manual (free on Wiki)
Climate folder
Control Components folder
"Blower motor resistor RHD" PDF
Did your new FSR cure the issue? Be good to know Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579695 14th Jan 2021 8:33am
AZUL
United States 2012 Range Rover HSE 5.0 V8 Buckingham Blue
WHAT IS WIKI???
Post #612746 15th Nov 2021 9:11pm
V8 Bob
Look at top right of header it contains a lot of common issues and copies of workshop manuals. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #612749 15th Nov 2021 9:37pm
AZUL
THANK YOU!!
Post #612803 16th Nov 2021 3:08pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Not exactly about the problem but;
Is The new Behr resistor spin’s faster in lowest setting?
So it blows too much from middle kind of discomforts when set for fresh air in cold weather.
But it warms faster too.
So which is correct? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #616153 13th Dec 2021 3:11pm
t5pete
Did ours not long back easy job to do just take your time
Post #616241 13th Dec 2021 9:56pm
