Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322
Page 6 of 6 <123456
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
TeeMyob wrote:
adapters arrived today but still not connecting
Is your "Apple connector" a genuine Apple cable?
Not all cables are equal, unfortunately, the genuine Apple cable should provide analog and usb audio out, which should, theoretically work with the land rover iPod cable.
** EDIT ** As per the video posted above, there's a suggestion a voltage converter is needed too...
Post #575239 6th Dec 2020 12:24pm
Siftah
Stuart- wrote:
This bloke on Youtube says an original LR lead, a spurious voltage converter and an Apple lead.
Does the Bovee thing offer any advantage over that messy cable set up other than being wireless?
And if using wireless Bovee, it would be this one plugged straight into the car without the LR lead? But it has 8% bad reviews. It seems they conk out after 2 months.
Kind of surprised with the need for the voltage converter, that's a new one on me but his video shows it working so, that kind of trumps everything Smile
I can't see that the Bovee does anything that doesn't do, it just does it wirelessly. Potentially less audio quality over the bluetooth link too, theoretically the cabled link will have the potential to sound better.
The Bovee still needs the Land Rover to 30-pin cable.
As per the video, no reason why you can't stream music from Apple Music or Spotify with either solutions.
Post #575240 6th Dec 2020 12:34pm
Stuart-
Yes, I am going to buy cables for reliability.
I've just done the searching so the rest of you don't have to. The converter is item number B003TJR2HS on Amazon. The Apple cable is item number MD824ZM/A but seems hard to find a genuine one, and the original Land Rover lead is part number LR031492, but they are megabucks so I bought a non-genuine one from fleabay. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #575517 8th Dec 2020 8:57pm
Stuart-
I just received these items, and it doesn't work. It sees the phone and that comes up on the screen, the phone charges, but it says "device error".
I did some Googling and it turns out that there is a software clash between these cars and the modern Apple software and/or the iPhone 8.
However, it seems the USB socket I use for charging that is next to the iPod socket can also be used as an input, and using a genuine Apple lead it gives the same device error.
So I am back to square one. Big Cry 2017 4.4 SDV8 Autobiography in black
Post #575745 11th Dec 2020 3:56pm
Siftah
Did you try it without the charge converter, same thing?
Post #575749 11th Dec 2020 4:43pm
Stuart-
Yes I did, Siftah. 2017 4.4 SDV8 Autobiography in black
Post #575750 11th Dec 2020 4:45pm
Siftah
meh, that sucks Sad
If you have a Gap IIDtool it may be worth checking what version of the software you're running on the bluetooth module, I guess it's possible there's been an update that fixes things.
It's unusual for Apple to change their spec's to retrospectively break things, as there's so many legacy devices out there (docks etc) that will also break.
At least you now have the LR cable so you can get the Bovee/Invery :\
Post #575751 11th Dec 2020 4:49pm
Stuart-
Yes, it looks like the Bovee thing is the way to go. But I am concerned from the Amazon reviews that 8% of them seem to conk out after two months. 2017 4.4 SDV8 Autobiography in black
Post #575753 11th Dec 2020 5:00pm
Siftah
Hmm, on the Spanish Amazon page where I bought mine (shows all reviews though), there's no mention of that... https://www.amazon.es/Airdual-Interfaz-Ada...07RMHVJ6P/
When you look through the reviews, despite the statistics, the only reviews are positive, with 1 which is in Italian and gives 1 star, but reading the text it also sounds positive... though I don't speak Italian Smile
Post #575755 11th Dec 2020 5:16pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
well mine is used came with my car looks battered but works flawlessly i was supprised at the clarity of sound when streaming from Deezer i can not hear any difference from from my high res MP3 on my USB stick 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575760 11th Dec 2020 6:29pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Only the iPod socket can handle the protocol. There is no way the normal USB does that.
Nothing wrong with the Bovee though. It just works. Leave it in there and let it connect for music to that and land rover Bluetooth for phone.
Post #575776 11th Dec 2020 10:01pm
Page 6 of 6 <123456
