![]() | Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322 |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Look on eBay for Bovee.
Change Junkie Member Since: 22 Sep 2017 Location: Buckinghamshire Posts: 35 ![]() ![]() ![]() |
Many thanks indeed. I presume you buy the one that has the jack plug to go into the Aux socket in the rear passenger consol where the temp controls are? |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Use the one that plugs into the Ipod connector |
As my honourable friend says,. Get the one that plugs into the iPod connector in the car. |
You must think me a tad dim but the iPod connector is in the centre consol right.... there isn’t another one lurking somewhere? Current:
Sorted! Thanks playmates. |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
Hi, did you go for the bovee or something else?
Just went on to Amazon. They have a range that are marque specific. Check there
Yes I went Bovee |
Thanks will take a look. Hope it's all working for you |
Yes, works for Android too, you can stream music from Spotify (and others) as well as play any music you have stored on your phone. You can skip tracks etc from the steering wheel controls. |
Thanks just the answer I'm looking for. Looks like the Porsche and Landover models are the same so can swap across both cars with the same unit. Now some homework if anywhere is less than £100. Will post my findings if I find it. MY11 Vogue 4.4 TDV8 - "African Queen" |
Usually on eBay for a little less than that. But, of course, it's not as quick to arrive as Amazon! |
Just to let you all know, Bovee works perfectly. Thanks for the advice all.
