Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322
Page 3 of 6 <123456>
supershuttle
Mine doesn't seem to charge, but I can move forward and backward through my Spotify playlists. Geoff
Post #500871 7th Jan 2019 5:43pm
Carl 40BMI RRSC
England 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
I’ve had a good read of this thread and would like to know if I can connect my iPhone 7plus to my 2005 vogue se without buying a bovee. I’ve seen the bit about 30 pin connector but where would that go??? 🤷‍♂️ I’m a newby to RR and have me a 4.2 supercharged 😬 loving it. I have loads of questions but will try find the answers on hear before asking. Thanks for your advice in advance though 👍
Post #500962 8th Jan 2019 8:57pm
Mr Tee
Goes into the genuine Land Rover cable which has a connector in the cubby box
Post #500968 8th Jan 2019 10:30pm
@carl, the LR ipod 30 pin connector will only work on the 2010-2012 years..
Post #500969 8th Jan 2019 10:35pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
If you have the SC you should have the aux socket - I use a Bluetooth device connected through this .. 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #500972 8th Jan 2019 11:06pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
don't know anything about audio stuff but car looks good with dark roof and wheels Smile
Post #500978 8th Jan 2019 11:59pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Can the Bovee be used to stream 'waze' app for sat nav like on the Audi. Question Question 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #500981 9th Jan 2019 1:35am
Carl 40BMI RRSC
i have a phone connection in the cubby box is that what you mean? Or is it something different? I do have an Aux socket in the rear but didn’t want a cable coming from the back if I could help it.
Post #500984 9th Jan 2019 7:00am
The only non surgical way on you model year is as Stan said the aux in socket in the back and a Bluetooth dongle on the end, then tuck them into the cubby and you don’t se it. The other way is the LR iPod kit, but these are expensive and require some disassembly of the dash for fitting. Check in the front glove boxes to see if you have something fitted. There may be something a previous owner has done.
Some have rewired the rear aux socket so it doubles up into the cubby. So you don’t have a cable. There is nothing that can't be fixed with a hammer😜😜
Post #501600 15th Jan 2019 8:55am
RangeRover313
Germany 2011 Range Rover Vogue 4.4 V8 Fuji White
Ive got a 30 pin to lightning adaPter.. no reaction Sad
So I’ll go for the bovee and let you know Cool
Post #504535 8th Feb 2019 11:21pm
supershuttle
Well after extensive testing I can confirm that the non genuine 30pin adapter doesn't work and I have been listening to downloaded Spotify playlists for the last few weeks with no problem using the genuine lead - no need for Bovee which is a shame because I wanted to mess about with one.
I usually set the iPhone playing before connecting because otherwise the RR doesn't see the playlist
I don't have charging through the lead though despite the fact that it charges my old iPod Confused Geoff
Post #504601 9th Feb 2019 3:37pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I've just picked up my 2010 model SC AB today (very nice!) and need to get the sounds sorted. Amazing that JLR didn't incorporate Bluetooth playback in a car like this, but hey.
So from reading this thread, my understanding is that I can either get a genuine cable, which will allow control via the steering wheel (and track info on the dash??) or go for the Bovee option for normal Bluetooth connection once the Bovee is plugged into the socket in the centre console?
Any thoughts on which option is best? Or is it just down to personal reference?
Ho much should I be paying for each option?
Thanks.
Post #504606 9th Feb 2019 3:53pm
this does BT streaming ,
https://www.fullfatrr.com/forum/topic50211.html
Post #504609 9th Feb 2019 3:59pm
Cappo
Hmm, I was trying to avoid adding too much extra hardware Stan, as I understand it the Bovee option is basically a Bluetooth dongle which you "lose" in the cubby?
Post #504611 9th Feb 2019 4:09pm
Cappo
Well, I bought a used cable from eBay which works, but doesn't charge. This is plugged into an old iPhone 4 with no SIM, just using it as an iPod or hotspotting off my iPhone 8 for Spotify, so no Apple adaptor lead involved as the iPhone 4 has the old style connector. Should it be charging? I'm wondering now whether the cable is a genuine JLR item; I thought it was.
Post #505199 15th Feb 2019 12:04pm
