![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
LeeKelley Member Since: 04 Nov 2019 Location: Birmingham, AL Posts: 11 ![]() ![]() ![]() |
Quick question: is that B1232-7A mechanical failure code for the back or is it not specific to back or bottom? |
More info... (I understand this is getting annoying, so I really appreciate the feedback!)
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Just had my heated driver's seat stop working, not got the time or weather at the moment to look into sorting the problem so as a temporary measure I've ordered a plug in heat pad, link below
carmaniac37 Member Since: 09 Nov 2019 Location: Rochester, NY Posts: 8 ![]() ![]() ![]() |
Haven't done any more investigation into this but the symptoms are unchanged. Might be worth swapping back units first but I'm looking at replacement seats from lower mileage vehicles. I've been using vindecoderz.com to try and determine the correct interior trim for a true match. The seat wear will be impossible to tell until its installed in the vehicle. On this topic though, does anyone have some insight on the feedback of interior color from a VIN decoder? I have found two potential matches to my vehicle. When I run my own VIN, it returns an interior color of "Sand Ox Lthr Sts Jet/Sand Int (Jet Car)" Both of the potential replacements return this "Sand Lthr Seats Sand/Jet Interior" Is the Oxford leather seat a different material, an option, in some way different, or just a labeling thing? Appreciate any help. I'll update with the seat back swap once this freak November snow storm is over here in NY. |
Finally did the seat back heater swap. Confirmed the problem. I guess my attempted repair wasn't good enough, these things are very fiddly. That being said, my repaired seat back heater always worked on back only but would fault out as soon as the base was turned on... interesting. Anyway, put the good one back in the driver seat because I deserve it and left the passenger empty. Ordering a replacement and we'll be in business. Cheers |
michaelpalmer7 Member Since: 08 May 2015 Location: Bedford Posts: 21 ![]() ![]() ![]() |
I have been reading this thread with interest as the driver and passenger seats on my 2007 322 are not working properly (I suspect the back motors from reading).
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
the ebay option seems new to me, having done a lot of experimenting (see earlier pages) - I think you should give it a go. I have some some non-working units I was going to put on ebay btw.
I think I will have a go at removing the driver’s one at the weekend and see what it looks like with the ducting etc. 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red) |
So I have just taken a proper look at both the ventilated seats on my 2007 Vogue SE and this appears to be the status:
Can't really comment regarding part umbers, only to say that 2007 is a good four years from 2011 so they might have updated within that time.
So having unhooked the white ribbons covering the blower and carefully pulling off the black plastic duct on the lower right which covers the filter and fan you can get access to the 3 TX20 screws that along with unplugging the connector and removing a couple of cable ties allowed the assembly to be carefully pulled out.
on the bench 4 x TX6 screws and removal of a couple of cable ties allowed me to seperate the duct and get the Peltier cell loose. I plugged back into the car and tested again and the fan is running silently at different speeds so happy thats fine and just gave it a blast of compressed air and a hoover to clean it up.
There is a slight crack in the duct albeit small which I have glued and will probably reinforce with some duct tape also upon reassembly to be 100% sure however the fact it was so small i'm pretty sure its the peltier cell at fault although I will reassemble with repaired duct first to be sure.
Visually it looks exactly the same as the one on eBay with the 2 green wires, 1 yellow & 1 blue but I am suspicious that my LR part number is different so I have sent some dimensions and pics to the seller to hopefully confirm it is the same. If it is I will order one solder it in and post my findings, assuming it does work anyone that can use a soldering iron could easily tackle this and assuming there is a reliable source of the peltier cells it should be a nice easy refurb job. Found the below guide on the jag forum which seems to explain the system operation very well: https://www.jaguarforums.com/forum/attachm...-seats.pdf In all honesty if I have to pay £300 for a new assembly I'm not going to lose any sleep but I quite enjoy doing stuff like this and given that my fan was really clean hopefully it will be a lasting repair rather than a sticky plaster.[/url] 2007 Range Rover L322 TDV8 Vogue SE (Rimini Red) |
please do Michael. Have you seen my experiment using a Mustang peltier ? Scroll on up to page 10 if you haven't. . . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
I did see that yes. Good work!
Hi Michael,
