Home > Technical (L322) > Wind screen wiper relay
Simonearp
England 2009 Range Rover Westminster TDV8 Adriatic Blue
Does any one know the location of the wind screen wiper relay on a late 2009 RR. Ive looked behind the battery and its not there ? Thanks
Post #565278 23rd Aug 2020 5:10pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
On early models, there was a single beige relay behind the main battery.
On later models, there are two relays: one to turn wipers on and off, the other for std speed vs fast speed.
I’m not sure when they changed. My 2002 TD6 had the original location; my 2010 TDV8 has the later location. The workshop manual for the later version is incorrect and still refers to the single relay behind the battery.
On my 2010, wiper relays are outlined in red in the pic below. This waterproof box of electronics, fuses and relays is in the engine compartment on the left as you look at it (on the right from the driver’s seat).
 Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #565297 23rd Aug 2020 7:24pm
Simonearp
Thanks Steve. I've replaced both the relays now and they still park in random positions. When I tap the motor they try to move - so I've ordered a 2nd hand motor. Thanks again
Post #565374 24th Aug 2020 4:52pm
WB
I've got the same issue with the windscreen wipers parking in the wrong position - was it the motor on yours Simon?
Many thanks
Post #612289 11th Nov 2021 10:40am
bishbosh10
It is almost certainly the motor. Any model year fits and £30 on ebay should find you one (LR new are £250 and 2 months lead time)
Just done mine. Leave the linkages in place and just change out the motor. A bit fiddly but not difficult. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #612305 11th Nov 2021 1:44pm
WB
That's great thank you bishbosh! I grabbed one on Ebay earlier - hopefully it's a good one!
I was a bit thrown by the BMW posts relating to the same issue on the same Valeo motor who had fixed it by replacing the relay but it makes more sense that its the park microswitch in the motor housing...
I've read a tip to mark the linkage position before detaching the old motor - was there anything else you'd recommend? I'm assuming I might need to remove the pollen filter housing but haven't looked closely yet at access to the nuts.
Thanks again for your help
Post #612364 11th Nov 2021 9:31pm
WB
Just done it - 20 mins and the most difficult part was getting the bonnet strut spring back in after putting it in service mode.
Really straightforward job - 10mm and 13mm spanners and marking the correct park position with a piece of masking tape before taking the motor off the spline.
The only other thing that may help others doing this is its a slightly unusual electrical connector. You have to push the white part (sides) backwards into the car to release it.
Thanks again for the tips and advice.
Post #612404 12th Nov 2021 12:06pm
