Home > Maintenance & Mods (L322) > Damped opening of lower tailgate
Page 11 of 12 <123 ... 101112>
wealy
Very kind of you - PM sent.
Post #376691 10th Mar 2016 1:11pm
miggit
Whistle You don't need a rivnut tool, just the rivnuts and a bit of cunning....... If you place a riv nut in the hole, hold it in place with a small ring spanner and pass a bolt through the spanner, you can apply pressure to the rivnut to stop it spinning while you tighten the bolt up.... when the bolt is tight undo it, remove the spanner and Mr. Green Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #376807 11th Mar 2016 8:10am
wealy
Sorted, Thumbs Up Thanks to cowman Mick for the demo of his home made tool...........
Nice and secure now.........
Post #376895 11th Mar 2016 4:52pm
darrenm
What’s the going rate for the kit
Post #539124 1st Jan 2020 5:16pm
rjff
Duckworths, May LAST year, good grief time flies Razz
https://www.fullfatrr.com/forum/topic51389...ate+damper Cheers
Richard
Gap IIDBT
Post #539131 1st Jan 2020 5:58pm
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
@miggit Did you ever make a kit? And did you do a double sided one?? Best part of £100 seems ridiculous!
Post #547688 20th Mar 2020 9:37am
Nismotec
Just stumbled on this thread..... was a bracket ever made? Did you go into production?
Post #564729 16th Aug 2020 8:21am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Those of you who've fitted the kit or had it as standard, does it damp the downward movement of the lower tailgate, stopping it "banging" at the bottom when opening ?
Reason for the question is that I had the opportunity to buy a second hand kit off a scrapped car for a bargain price, but when I tested that gas strut it appeared to only damp / slow movement in the upward direction. So it appeared to prevent you slamming the tailgate shut, but NOT damping it open. Because of that I decided it wasn't worth buying. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #564743 16th Aug 2020 1:22pm
it does dampen the ladt bit of the downward motion...
maybe the kit you tedted hsd the strut upside down? ... - .- -.
Post #564747 16th Aug 2020 2:16pm
Pawl
Stan,
thanks for the comment. I was surprised & thought I'd misunderstood how it worked.
I think I need to relook at how the damper mounts & then check if the parts are still available - it would have been a bargain, lol. Paul,
Post #564777 16th Aug 2020 9:13pm
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Are the parts still available for this modification
If anybody’s got spares they want to sell off please pm
Post #575971 13th Dec 2020 2:56pm
rjff
If you email Rob at Duckworths, not via the suppliers section on here, or ring him he will be able to tell you if the kit or parts are available and the cost.
Edit . eerr May 2019
Richard
Gap IIDBT
Post #575986 13th Dec 2020 3:43pm
andyfid
Excellent thank you 🙏
Post #575995 13th Dec 2020 4:33pm
rjff
You are welcome Andy Cheers
Richard
Gap IIDBT
Post #576006 13th Dec 2020 5:29pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
I don't know about the availability overseas but here in the USA the parts are still available. I just got all of the needed parts from my local Land Rover dealer. It cost $110.92 USD plus our local sales tax.
  • Support Cylinder (LR017455)
  • Support Cylinder Bracket (LR021053)
  • Strap (LR038048)
  • Distance Sensor Screw x2 (LR003808)
You'll need to drill two holes to mount the Support Cylinder Bracket. I also bought some nyloc nuts to secure the screws from inside the tailgate.
And don't forget to protect the bare metal after drilling the two holes for the bracket so it doesn't rust through!
Larry.[/list] 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #576007 13th Dec 2020 5:29pm
