![]() | Home > Maintenance & Mods (L322) > TDV8 3.6 FFRR Oil Change - How to |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Does 2nd plug empty another part in sump?
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I’ve never taken the sump off To look so I don’t know For sure. However, I assume they are part of the one sump and for some reason there is a shallow divide between the main sump, which I drain using suction tube into the dipstick, and 2nd sump I drain by removing the sump plug. ______________________________
There are photos of sumps on Google but I did not really understand the inside design. 2010 3.6tdv8 180k km.
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
There is a more seperate section (found a pic) , It is important to drian the second plug to help prevent sludge build up which could slowly but surely starve the turbo chargers for oil... You probably get a cup of oil out of it and it drins into a rail and goes everywhere ... either way you want to get as much as the old oil out as possible
No idea why it has to be so hard to upload a bloody picture ...
First select Choose photos then go to archive or photos
It may be something to do with my browser.... i never got the mini picture which was the confusing part... all good and thank you
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
You can always fit a couple of these in place of the original drain plugs so that you can attach a length of hose to drain rather than soaking/splashing the chassis
Marzipan Member Since: 02 Apr 2020 Location: North West Posts: 23 ![]() ![]() ![]() |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
On Sam's 4.4, he also uses suction https://www.youtube.com/watch?v=3-Tpdfnf3Lc However, I can't seem to find the suction port on the 3.6. Where is it? Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
On the 3.6 you drain it from the sump.
good heavens! Tym
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Cant we do it via the dipstick port in 3.6 ? |
I saw a video of someone doing that because his sump plug was rounded. I just wondered if there was a "proper" suction port or not, which it looks like there isn't. Tym
