Home > Maintenance & Mods (L322) > TDV8 3.6 FFRR Oil Change - How to |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Does 2nd plug empty another part in sump?
4th Aug 2020 12:52pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I’ve never taken the sump off To look so I don’t know For sure. However, I assume they are part of the one sump and for some reason there is a shallow divide between the main sump, which I drain using suction tube into the dipstick, and 2nd sump I drain by removing the sump plug. ______________________________
4th Aug 2020 7:39pm |
There are photos of sumps on Google but I did not really understand the inside design. 2010 3.6tdv8 180k km.
4th Aug 2020 9:45pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
There is a more seperate section (found a pic) , It is important to drian the second plug to help prevent sludge build up which could slowly but surely starve the turbo chargers for oil... You probably get a cup of oil out of it and it drins into a rail and goes everywhere ... either way you want to get as much as the old oil out as possible
5th Aug 2020 4:47am |
No idea why it has to be so hard to upload a bloody picture ...
5th Aug 2020 5:02am |
First select Choose photos then go to archive or photos
5th Aug 2020 7:27am |
It may be something to do with my browser.... i never got the mini picture which was the confusing part... all good and thank you
5th Aug 2020 2:26pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
You can always fit a couple of these in place of the original drain plugs so that you can attach a length of hose to drain rather than soaking/splashing the chassis
16th Aug 2020 3:29pm |
Marzipan Member Since: 02 Apr 2020 Location: North West Posts: 23 |
7th Mar 2021 7:09pm |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 |
On Sam's 4.4, he also uses suction https://www.youtube.com/watch?v=3-Tpdfnf3Lc However, I can't seem to find the suction port on the 3.6. Where is it? Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
30th Aug 2022 10:06am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3243 |
On the 3.6 you drain it from the sump.
30th Aug 2022 10:53am |
good heavens! Tym
30th Aug 2022 10:58am |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Cant we do it via the dipstick port in 3.6 ? |
30th Aug 2022 11:07am |
I saw a video of someone doing that because his sump plug was rounded. I just wondered if there was a "proper" suction port or not, which it looks like there isn't. Tym
30th Aug 2022 11:14am |
