Home > Maintenance & Mods (L322) > TDV8 3.6 FFRR Oil Change - How to
Page 2 of 3 <123>
rar110
Even when I’ve asked for the 2nd simp plug to be drained, the workshop didn’t do it. So I do my own now with oil suction, which is a lot cleaner and easier. Only a dribble comes out of the 2nd sump plug, when the main sump is emptied. ______________________________
Post #563520 4th Aug 2020 7:47am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Does 2nd plug empty another part in sump?
Is that not connected to whole sump?
If it is can’t we drain from 2nd plug before opening 1st? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563557 4th Aug 2020 12:52pm
rar110
I’ve never taken the sump off To look so I don’t know For sure. However, I assume they are part of the one sump and for some reason there is a shallow divide between the main sump, which I drain using suction tube into the dipstick, and 2nd sump I drain by removing the sump plug. ______________________________
Post #563599 4th Aug 2020 7:39pm
umitbat
There are photos of sumps on Google but I did not really understand the inside design. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563619 4th Aug 2020 9:45pm
Bluegreygreen Rangie 2
Australia
There is a more seperate section (found a pic) , It is important to drian the second plug to help prevent sludge build up which could slowly but surely starve the turbo chargers for oil... You probably get a cup of oil out of it and it drins into a rail and goes everywhere ... either way you want to get as much as the old oil out as possible
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #563629 5th Aug 2020 4:47am
Australia
No idea why it has to be so hard to upload a bloody picture ...
GAP Diagnostics
Post #563631 5th Aug 2020 5:02am
umitbat
First select Choose photos then go to archive or photos
Select photo
Then Click Upload
Then Click uploaded mini photo
It will jump inside the thread Mr. Green 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563645 5th Aug 2020 7:27am
Australia
It may be something to do with my browser.... i never got the mini picture which was the confusing part... all good and thank you
GAP Diagnostics
Post #563699 5th Aug 2020 2:26pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
You can always fit a couple of these in place of the original drain plugs so that you can attach a length of hose to drain rather than soaking/splashing the chassis
www.ezoildrain.com
Post #564753 16th Aug 2020 3:29pm
Marzipan
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hi Andrew, thanks for posting the info on the oil change I found it very useful and used plastic milk bottles to avoid spillage.
First class result
Thanks again
Post #586634 7th Mar 2021 7:09pm
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
On Sam's 4.4, he also uses suction
https://www.youtube.com/watch?v=3-Tpdfnf3Lc
However, I can't seem to find the suction port on the 3.6.
Where is it? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #641413 30th Aug 2022 10:06am
JayGee
On the 3.6 you drain it from the sump.
make provision for what happens at 18.09 which is probably why they went for a suction extraction on the 4.4. 2012 TDV8 Vogue (L322)
Post #641418 30th Aug 2022 10:53am
tymh
good heavens! Tym
Post #641422 30th Aug 2022 10:58am
Bingo_123
Cant we do it via the dipstick port in 3.6 ?
Post #641427 30th Aug 2022 11:07am
tymh
I saw a video of someone doing that because his sump plug was rounded. I just wondered if there was a "proper" suction port or not, which it looks like there isn't. Tym
Post #641429 30th Aug 2022 11:14am
Page 2 of 3 <123>
